Hi, when I got the router, I could login to admin panel anytime I wanted and easily too. After months, I could login only after resetting the router. Now, even after resetting, it seems to be very difficult.
I looked into the internet and saw the various suggestions there, but none of them worked for me.
Please help me.
Thank you.
Here is the ipconfig log:
Please help me.
Thank you.
Code:
C:\WINDOWS\system32>ipconfig /all
Windows IP Configuration
Host Name . . . . . . . . . . . . : ADMIN
Wireless LAN adapter Local Area Connection* 2:
Physical Address. . . . . . . . . : 76-29-AF-2C-90-55
Ethernet adapter Ethernet 2:
Physical Address. . . . . . . . . : 68-F7-28-50-6E-46
Link-local IPv6 Address . . . . . : fe80::bdc8:b551:9d4e:5491%7(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.1.5(Preferred)
Lease Obtained. . . . . . . . . . : Wednesday, August 2, 2017 10:04:34 PM
Lease Expires . . . . . . . . . . : Saturday, August 5, 2017 10:17:50 PM
DHCPv6 IAID . . . . . . . . . . . : 90765096
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-1D-58-95-B0-68-F7-28-50-6E-46
Ethernet adapter Ethernet 4:
Description . . . . . . . . . . . : Anchorfree HSS VPN Adapter
Physical Address. . . . . . . . . : 00-FF-C9-62-3B-62
Wireless LAN adapter Wi-Fi:
Description . . . . . . . . . . . : Realtek RTL8723BE Wireless LAN 802.11n PCI-E NIC
Physical Address. . . . . . . . . : 74-29-AF-2C-90-55
Tunnel adapter Local Area Connection* 12:
Description . . . . . . . . . . . : Microsoft Teredo Tunneling Adapter
IPv6 Address. . . . . . . . . . . : 2001:0:4137:9e76:4cd:13e8:3f57:fefa(Preferred)
Link-local IPv6 Address . . . . . : fe80::4cd:13e8:3f57:fefa%13(Preferred)
Default Gateway . . . . . . . . . : ::
DHCPv6 IAID . . . . . . . . . . . : 218103808
