Freezing and restarting
Pw123456
13
25
Hi all
New to this forum and I'm hopeful to get some good tips..
So I have purchased a prebuilt PC through an online supplier. I have an issue which just will not go away
So when I boot up the pc it is ok untill I open Google for example (not program specific as I have tried different programs) where a few minutes later the screen freezes and pixilated a bit and then restarts with no warning..
I have checked starup apps and nothing seems out of place and have disabled a few apps and nothin. I have checked the CPU temps and it's not going above 30 Deg C.. Updated drivers for motherboard and GPU and still the same thing happens.. I also ran a memory test and comes back no issues..
Sorry for such a trivial question but what else could I try to fix this?
Thanks in advance
Since this a new system you may want to get a trouble ticket started with them if it is still has a warranty.
Need complete system specs including the make and model of the PSU.
If it can run long enough let get some information this way.
If this is a SSD skip the Check Disk
Lets run a check disk on the HDD
Run CHKDSK using Command Prompt | PC Help Forum
Download Crystal Disk Information this will give us a more better view of the drive.
Download – Crystal Dew World (crystalmark.info)
Make sure to download the ZP. This will be the portable version and there is no install.
Uncompressed the ZIP file and run the DiskInfo64.exe file.
Post a screen shot.
Other may have more information for you.
So when getting info for you the screen pixelated and for once didn't restart by instead recovered.. all temps are fine.. just to mention I haven't been one this pc any longer than a day that's how new it is..
It can be a hardware failure to just something that has come loose during shipping and need to be reseated.
Which is why I stated to contact them so they have documentation that this is happening. That way you are covered under the warranty to have if any of the parts need to be replaced.
Hi
Quick update
So I contacted the pc builder and they have suggested to reinstall windows 10 and drivers for gpu from online which intend on doing tomorrow. If that doesn't work they will pick up the pc and have a look for me. Have 3 year Warrenty with the pc builder and they are very helpful. Fingers crossed.
I'll keep you all updated
Thanks
Hi
I have manage to update you drives and reinstall windows and still no change.. get in contact with pc builder at start of the week
Thanks
It sounds like you need to go ahead and send that in for warranty work :)
Usually a reboot when googling is the heatsink has become loose during shipping.
