Solved Flash Player Update Settings
Eddie Paul Litz
464
30
35
Novelty Ohio
How do I change the Flash Player Update Settings?
As I recall, you set those when you install the program. So, you would need to uninstall, then download a fresh copy to apply the settings of your choice.
Alright, I suppose we can mark this one as solved for you then?
