So I may have suffered some kind of hiccup or power failure that caused an issue with the USB ports on my computer or hub. Regardless, I ended up with the issue where the drive is now detected as RAW and unable to be detected by Windows - it gives both the "Parameter is missing" error and asks me to format.
PhotoRec is able to recover files, so at the very least I know the files are still there, but I'd really like to be able to recover the disk entirely to be able to get the files out in the original context.
It's my first time trying TestDisk, but I read some tutorials/instructions but was kind of stuck.
I did Analyze, and found the partition:
But when I try to list files, I get this error:
I saw elsewhere that you can go to Advanced options to try to fix the boot sector directly by recovering from a backup, but the option doesn't appear:
It does appear when I select a working drive (and I'm also able to view the files as well).
What do I need to try next? Do I need to do a deep scan in order to see the "Backup BS" (boot sector) option? It's an 8tb drive so it'll take forever, but I don't mind if that's really the only option I have.
Or is there something else I can try?
Any help is much appreciated. Thank you.
