First time blue screen help
PaCrAt11
4
28
Can anyone tell me what this means, only started happening last 48 hours, has only happened twice
Will do thanks :) so far I've gone through cc cleaner and deleted what needed to be aswell as malware bytes and spybot search and destroy and deleted and fixed any issues they found
In conjunction with the BSOD prework, please do the following:
Flush DNS
Report IE Proxy Settings
Reset IE Proxy Settings
Report FF Proxy Settings
Reset FF Proxy Settings
List content of Hosts
List IP Configuration
List Winsock Entries
List Installed Programs
List Devices (Only Problems)
