Custom build:Please provide information about your computer, is it a custom build or brand name such as Dell or HP, if a brand name, provide the model name or series number (not serial) if a custom build post the brand and model name or number for the CPU, MB, the RAM (including the amount) add on video card if one is used and the PSU (power supply unit) providing these details will enable folk to better assist you.
Cooler Master MasterLiquid ML240L
does that mean the motherboard is trash
Remove the MB and do a barebones set-up on a piece of cardboard (make sure it is larger than the MB) only connect the PSU, the GFX card, screen, 1 stick of RAM and the keyboard.
IF your MB doesn`t have a power test switch you will then need to short out the 2 power on pins on the MB header to get the PSU to activate, you can use a small flat bladed screwdriver or a paper clip bent into a U shape, this is perfectly safe if you do not touch anything else, the idea is to see if we can get a BIOS screen if you do you can then add one component at a time until you find the problem component, you must power down and remove the power cord from the wall before adding another component,
Other things worth checking include, if you used stand offs beneath the MB are they in the correct locations (only where there is a screw hole in the MB) otherwise the MB will short out, check for stray screws or bared wires for the same reason, make sure the jumper cap that can be used for clearing the CMOS is not missing or on the wrong pins and finally try removing the CMOS battery for a few moments and then replace it, this will clear any possible bad MB settings.
If after checking all the above the issue is not resolved I would suspect a bad MB or CPU.
