Greetings all - I'm new to PC Help Forum.
I'm about to build my first AMD Ryzen Threadripper on an AsRock X399M micro ATX board.
The motherboard has space for up to 3 x M.2 SSD PCIe. Just looking for some advice on drive strategy? Should I have separate drives - one for OS + Apps and one for data?
I don't think I need much more than about 40 GB for OS + Apps, and about 300 GB for data. My plan is to buy a Samsung 970 Pro 512 GB for primary data storage, plus maybe a second SSD for backup . Or I could just have an external SSD on USB 3 for backup. The external drive would give me the option to take it off-site. I don't use any cloud services for backup.
In terms of OS and apps , I'm using Windows 10, MS Office, Visual Studio, Adobe After Effects, Media Encoder...
I'm not sure if I want or need the overhead of RAID.
The ASRock board has support for the following:
www.asrock.com
I think it's the only mATX board that supports Ryzen Threadripper
- 8 SATA3
- 2 Ultra M.2 (PCIe Gen3 x4)
- 1 Ultra M.2 (PCIe Gen3 x4 & SATA3)
ASRock > X399M Taichi
Supports AMD TR4 Socket Ryzen Threadripper Series CPUs; IR Digital PWM, 11 Power Phase & Dr. MOS; Supports DDR4 3600+(OC); 3 PCIe 3.0 x16; NVIDIA Quad SLI™, AMD Quad CrossFireX™; 7.1 CH HD Audio (Realtek ALC1220 Audio Codec), Supports DTS Connect; 8 SATA3, 2 Ultra M.2 (PCIe Gen3x4), 1 Ultra M.2...
