Hi all,
For a long time i have been having issues with my external hard drive hooked up to my laptop.
I believe / think that there was always a bit of an issue. Mainly, it disconnects/reconnects, at given times.
I mainly use it for games. And sometimes when i game i see the windows load cursor ( the little blue circle) spinning around.
And not long after it works fine again. It's like a lagging interruption. Also sometimes it fails to recognize the hard drive totally.
Lately it's been doing this more and more. and i keep unplugging it. Reconnecting it to another usb port in my laptop.
And i even purchased an USB hub with external power-supply. As i also use an USB-keyboard + USB mouse on my laptop.
To deduct if it was a power problem. It's a seagate expansion 1TB drive, with USB 3.0. and my laptop also got an USB 3.0 port.
I did some other troubleshooting before i came here.
1. I went to device manager, changed policies on hard drive to best performance.
2. In device manager. I disallowed all devices in universal serial bus controllers the computer to turn off device for saving power.
3. I also performed step two in my Power options located at the battery of my laptop. It's always on charger anyway.
4. I also tried to re-install the drivers for USB controllers.
Is there anything else i could try? When i reconnect my hard drive it says it needs to repair / scan for fixing errors too.
I tried that, but it gets stuck. Whenever i run an application and some form of data retrieving is going on. The blue light of my hard drive starts blinking.
Is the external hard drive not good anymore?
