Ethernet throughput seems to spike up high
changinglater
16
Ethernet throughput on my PC seems to spike up really high at some points, then dies down. When is spikes it seems like my internet cuts out for a second (livestream buffers and I get dropped out of programs like mumble). This usually happens when i open a new program or start downloading.
mTZuc
Hi,
Flush DNS
Report IE Proxy Settings
Reset IE Proxy Settings
Report FF Proxy Settings
Reset FF Proxy Settings
List content of Hosts
List IP Configuration
List Winsock Entries
List Installed Programs
List Devices (Only Problems)
Also who is your ISP?
======================== Flush DNS: ===================================
Windows IP Configuration
Proxy is not enabled.
No Proxy Server is set.
Intel(R) I211 Gigabit Network Connection = Ethernet 2 (Connected)
# IPv4 Configuration
pushd interface ipv4
reset
set global icmpredirects=enabled
add route prefix=0.0.0.0/0 interface="Hamachi" nexthop=25.0.0.1 publish=Yes
set interface interface="Local Area Connection* 1" forwarding=enabled advertise=enabled nud=enabled ignoredefaultroutes=disabled
set interface interface="Ethernet 2" forwarding=enabled advertise=enabled nud=enabled ignoredefaultroutes=disabled
set interface interface="Hamachi" forwarding=enabled advertise=enabled metric=9000 nud=enabled ignoredefaultroutes=disabled
set interface interface="ethernet_0" forwarding=enabled advertise=enabled nud=enabled ignoredefaultroutes=disabled
set interface interface="ethernet_4" forwarding=enabled advertise=enabled nud=enabled ignoredefaultroutes=disabled
set subinterface interface= subinterface=ethernet_7 mtu=1404
set subinterface interface= subinterface=ethernet_5 mtu=1404
popd
# End of IPv4 configuration
Host Name . . . . . . . . . . . . : JakesPC
DNS Suffix Search List. . . . . . : hsd1.ca.comcast.net.
Ethernet adapter Ethernet 2:
Connection-specific DNS Suffix . : hsd1.ca.comcast.net.
Description . . . . . . . . . . . : Intel(R) I211 Gigabit Network Connection
Physical Address. . . . . . . . . : 4C-CC-6A-8C-3D-57
IPv6 Address. . . . . . . . . . . : 2601:646:8d81:98b0:d52e:28b9:d4a6:32da(Preferred)
Temporary IPv6 Address. . . . . . : 2601:646:8d81:98b0:5149:1657:d3d6:388e(Deprecated)
Temporary IPv6 Address. . . . . . : 2601:646:8d81:98b0:a880:99bc:2986:8118(Preferred)
Link-local IPv6 Address . . . . . : fe80::d52e:28b9:d4a6:32da%3(Preferred)
IPv4 Address. . . . . . . . . . . : 10.0.0.22(Preferred)
Lease Obtained. . . . . . . . . . : Saturday, July 8, 2017 11:46:11 AM
Lease Expires . . . . . . . . . . : Sunday, July 16, 2017 5:05:09 PM
Default Gateway . . . . . . . . . : fe80::200:caff:fe11:2233%3
10.0.0.1
DHCP Server . . . . . . . . . . . : 10.0.0.1
DHCPv6 IAID . . . . . . . . . . . : 139250794
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-20-8D-69-CC-4C-CC-6A-8C-3D-57
DNS Servers . . . . . . . . . . . : 2001:558:feed::1
2001:558:feed::2
75.75.75.75
75.75.76.76
Tunnel adapter Local Area Connection* 2:
Description . . . . . . . . . . . : Microsoft Teredo Tunneling Adapter
Server: cdns01.comcast.net
Address: 2001:558:feed::1
Addresses: 2607:f8b0:4005:80a::200e
216.58.194.174
Pinging google.com [2607:f8b0:4005:808::200e] with 32 bytes of data:
Reply from 2607:f8b0:4005:808::200e: time=14ms
Reply from 2607:f8b0:4005:808::200e: time=10ms
Ping statistics for 2607:f8b0:4005:808::200e:
Minimum = 10ms, Maximum = 14ms, Average = 12ms
Addresses: 2001:4998:c:a06::2:4008
2001:4998:58:c02::a9
2001:4998:44:204::a7
98.138.253.109
206.190.36.45
98.139.180.149
Pinging yahoo.com [2001:4998:58:c02::a9] with 32 bytes of data:
Reply from 2001:4998:58:c02::a9: time=78ms
Reply from 2001:4998:58:c02::a9: time=83ms
Ping statistics for 2001:4998:58:c02::a9:
Minimum = 78ms, Maximum = 83ms, Average = 80ms
Interface List
3...4c cc 6a 8c 3d 57 ......Intel(R) I211 Gigabit Network Connection
2...00 00 00 00 00 00 00 e0 Microsoft Teredo Tunneling Adapter
IPv4 Route Table
Active Routes:
0.0.0.0 0.0.0.0 10.0.0.1 10.0.0.22 25
10.0.0.0 255.255.255.0 On-link 10.0.0.22 281
10.0.0.22 255.255.255.255 On-link 10.0.0.22 281
10.0.0.255 255.255.255.255 On-link 10.0.0.22 281
224.0.0.0 240.0.0.0 On-link 10.0.0.22 281
255.255.255.255 255.255.255.255 On-link 10.0.0.22 281
Persistent Routes:
Network Address Netmask Gateway Address Metric
0.0.0.0 0.0.0.0 25.0.0.1 Default
IPv6 Route Table
Active Routes:
3 281 ::/0 fe80::200:caff:fe11:2233
1 331 ::1/128 On-link
3 281 2601:646:8d81:98b0::/64 On-link
3 281 2601:646:8d81:98b0:5149:1657:d3d6:388e/128
On-link
3 281 2601:646:8d81:98b0:a880:99bc:2986:8118/128
On-link
3 281 2601:646:8d81:98b0:d52e:28b9:d4a6:32da/128
On-link
3 281 fe80::/64 On-link
3 281 fe80::d52e:28b9:d4a6:32da/128
On-link
1 331 ff00::/8 On-link
3 281 ff00::/8 On-link
Persistent Routes:
0 9000 ::/0 2620:9b::1900:1
0 4294967295 2620:9b::/96 On-link
Catalog5 01 C:\WINDOWS\SysWOW64\napinsp.dll [54784] (Microsoft Corporation)
Catalog5 02 C:\WINDOWS\SysWOW64\pnrpnsp.dll [70144] (Microsoft Corporation)
Catalog5 03 C:\WINDOWS\SysWOW64\pnrpnsp.dll [70144] (Microsoft Corporation)
Catalog5 04 C:\WINDOWS\SysWOW64\NLAapi.dll [63488] (Microsoft Corporation)
Catalog5 05 C:\WINDOWS\SysWOW64\mswsock.dll [305568] (Microsoft Corporation)
Catalog5 06 C:\WINDOWS\SysWOW64\winrnr.dll [23040] (Microsoft Corporation)
Catalog9 01 C:\WINDOWS\SysWOW64\mswsock.dll [305568] (Microsoft Corporation)
Catalog9 02 C:\WINDOWS\SysWOW64\mswsock.dll [305568] (Microsoft Corporation)
Catalog9 03 C:\WINDOWS\SysWOW64\mswsock.dll [305568] (Microsoft Corporation)
Catalog9 04 C:\WINDOWS\SysWOW64\mswsock.dll [305568] (Microsoft Corporation)
Catalog9 05 C:\WINDOWS\SysWOW64\mswsock.dll [305568] (Microsoft Corporation)
Catalog9 06 C:\WINDOWS\SysWOW64\mswsock.dll [305568] (Microsoft Corporation)
Catalog9 07 C:\WINDOWS\SysWOW64\mswsock.dll [305568] (Microsoft Corporation)
Catalog9 08 C:\WINDOWS\SysWOW64\mswsock.dll [305568] (Microsoft Corporation)
Catalog9 09 C:\WINDOWS\SysWOW64\mswsock.dll [305568] (Microsoft Corporation)
Catalog9 10 C:\WINDOWS\SysWOW64\mswsock.dll [305568] (Microsoft Corporation)
Catalog9 11 C:\WINDOWS\SysWOW64\mswsock.dll [305568] (Microsoft Corporation)
Catalog9 12 C:\WINDOWS\SysWOW64\mswsock.dll [305568] (Microsoft Corporation)
x64-Catalog5 01 C:\Windows\System32\napinsp.dll [66560] (Microsoft Corporation)
x64-Catalog5 02 C:\Windows\System32\pnrpnsp.dll [85504] (Microsoft Corporation)
x64-Catalog5 03 C:\Windows\System32\pnrpnsp.dll [85504] (Microsoft Corporation)
x64-Catalog5 04 C:\Windows\System32\NLAapi.dll [79872] (Microsoft Corporation)
x64-Catalog5 05 C:\Windows\System32\mswsock.dll [358600] (Microsoft Corporation)
x64-Catalog5 06 C:\Windows\System32\winrnr.dll [31232] (Microsoft Corporation)
x64-Catalog9 01 C:\Windows\System32\mswsock.dll [358600] (Microsoft Corporation)
x64-Catalog9 02 C:\Windows\System32\mswsock.dll [358600] (Microsoft Corporation)
x64-Catalog9 03 C:\Windows\System32\mswsock.dll [358600] (Microsoft Corporation)
x64-Catalog9 04 C:\Windows\System32\mswsock.dll [358600] (Microsoft Corporation)
x64-Catalog9 05 C:\Windows\System32\mswsock.dll [358600] (Microsoft Corporation)
x64-Catalog9 06 C:\Windows\System32\mswsock.dll [358600] (Microsoft Corporation)
x64-Catalog9 07 C:\Windows\System32\mswsock.dll [358600] (Microsoft Corporation)
x64-Catalog9 08 C:\Windows\System32\mswsock.dll [358600] (Microsoft Corporation)
x64-Catalog9 09 C:\Windows\System32\mswsock.dll [358600] (Microsoft Corporation)
x64-Catalog9 10 C:\Windows\System32\mswsock.dll [358600] (Microsoft Corporation)
x64-Catalog9 11 C:\Windows\System32\mswsock.dll [358600] (Microsoft Corporation)
x64-Catalog9 12 C:\Windows\System32\mswsock.dll [358600] (Microsoft Corporation)
Application errors:
Error: (07/09/2017 09:00:16 PM) (Source: Application Error) (User: )
Description: Faulting application name: Photoshop.exe, version: 18.1.1.252, time stamp: 0x58fefd04
Faulting module name: Dicom.8bi, version: 18.1.1.252, time stamp: 0x58feff65
Exception code: 0xc0000005
Fault offset: 0x00000000004266a0
Faulting process id: 0x2cd0
Faulting application start time: 0xPhotoshop.exe0
Faulting application path: Photoshop.exe1
Faulting module path: Photoshop.exe2
Report Id: Photoshop.exe3
Faulting package full name: Photoshop.exe4
Faulting package-relative application ID: Photoshop.exe5
Error: (07/09/2017 12:48:10 PM) (Source: Microsoft-Windows-Immersive-Shell) (User: JAKESPC)
Description: Activation of app Microsoft.Windows.Photos_8wekyb3d8bbwe!App failed with error: -2144927141 See the Microsoft-Windows-TWinUI/Operational log for additional information.
Error: (07/08/2017 08:08:10 PM) (Source: Microsoft-Windows-Immersive-Shell) (User: JAKESPC)
Description: Activation of app Microsoft.SkypeApp_kzf8qxf38zg5c!App failed with error: -2144927141 See the Microsoft-Windows-TWinUI/Operational log for additional information.
Error: (07/08/2017 06:12:00 PM) (Source: Microsoft-Windows-Immersive-Shell) (User: JAKESPC)
Description: Activation of app Microsoft.Windows.Photos_8wekyb3d8bbwe!App failed with error: -2147023170 See the Microsoft-Windows-TWinUI/Operational log for additional information.
Error: (07/02/2017 03:31:42 PM) (Source: Microsoft-Windows-Immersive-Shell) (User: JAKESPC)
Description: Activation of app Microsoft.LockApp_cw5n1h2txyewy!WindowsDefaultLockScreen failed with error: -2144927142 See the Microsoft-Windows-TWinUI/Operational log for additional information.
Error: (07/02/2017 02:19:08 PM) (Source: Microsoft-Windows-Immersive-Shell) (User: JAKESPC)
Description: Activation of app Microsoft.BingWeather_8wekyb3d8bbwe!App failed with error: -2144927148 See the Microsoft-Windows-TWinUI/Operational log for additional information.
Error: (07/02/2017 01:22:44 PM) (Source: MSDTC Client 2) (User: )
Description: 0x8007085A
Error: (07/02/2017 01:20:00 PM) (Source: MSDTC Client 2) (User: )
Error: (07/02/2017 01:20:00 PM) (Source: MSDTC 2) (User: )
System errors:
Error: (07/09/2017 07:13:17 PM) (Source: DCOM) (User: NT AUTHORITY)
Description: {F3B4E234-7A68-4E43-B813-E4BA55A065F6}
Error: (07/09/2017 05:05:17 PM) (Source: DCOM) (User: NT AUTHORITY)
Description: application-specificLocalActivation{D63B10C5-BB46-4990-A94F-E40B9D520160}{9CA88EE3-ACB7-47C8-AFC4-AB702511C276}NT AUTHORITYSYSTEMS-1-5-18LocalHost (Using LRPC)UnavailableUnavailable
Error: (07/09/2017 12:48:14 PM) (Source: DCOM) (User: NT AUTHORITY)
Error: (07/09/2017 12:48:10 PM) (Source: DCOM) (User: JAKESPC)
Description: Microsoft.Windows.Photos_2017.18062.12990.0_x64__8wekyb3d8bbwe!App.AppXy9rh3t8m2jfpvhhxp6y2ksgeq77vymbq.mca
Error: (07/08/2017 11:02:35 PM) (Source: Microsoft-Windows-Kernel-Power) (User: )
Description: 5
Error: (07/08/2017 08:08:10 PM) (Source: DCOM) (User: JAKESPC)
Description: Microsoft.SkypeApp_11.18.614.0_x64__kzf8qxf38zg5c!App
Error: (07/08/2017 07:57:30 PM) (Source: DCOM) (User: NT AUTHORITY)
Error: (07/08/2017 06:12:02 PM) (Source: DCOM) (User: NT AUTHORITY)
Error: (07/08/2017 03:45:19 PM) (Source: DCOM) (User: NT AUTHORITY)
Error: (07/08/2017 11:51:03 AM) (Source: Service Control Manager) (User: )
Description: The Delivery Optimization service hung on starting.
Microsoft Office Sessions:
Error: (07/09/2017 09:00:16 PM) (Source: Application Error)(User: )
Description: Photoshop.exe18.1.1.25258fefd04Dicom.8bi18.1.1.25258feff65c000000500000000004266a02cd001d2f930f42c57d1C:\Program Files\Adobe\Adobe Photoshop CC 2017\Photoshop.exeC:\Program Files\Adobe\Adobe Photoshop CC 2017\Required\Plug-ins\File Formats\Dicom.8bicc1b8e9c-3a12-4746-a6ac-ddab051be0a0
Error: (07/09/2017 12:48:10 PM) (Source: Microsoft-Windows-Immersive-Shell)(User: JAKESPC)
Description: Microsoft.Windows.Photos_8wekyb3d8bbwe!App-2144927141
Error: (07/08/2017 08:08:10 PM) (Source: Microsoft-Windows-Immersive-Shell)(User: JAKESPC)
Description: Microsoft.SkypeApp_kzf8qxf38zg5c!App-2144927141
Error: (07/08/2017 06:12:00 PM) (Source: Microsoft-Windows-Immersive-Shell)(User: JAKESPC)
Description: Microsoft.Windows.Photos_8wekyb3d8bbwe!App-2147023170
Error: (07/02/2017 03:31:42 PM) (Source: Microsoft-Windows-Immersive-Shell)(User: JAKESPC)
Description: Microsoft.LockApp_cw5n1h2txyewy!WindowsDefaultLockScreen-2144927142
Error: (07/02/2017 02:19:08 PM) (Source: Microsoft-Windows-Immersive-Shell)(User: JAKESPC)
Description: Microsoft.BingWeather_8wekyb3d8bbwe!App-2144927148
Error: (07/02/2017 01:22:44 PM) (Source: MSDTC Client 2)(User: )
Error: (07/02/2017 01:20:00 PM) (Source: MSDTC Client 2)(User: )
Error: (07/02/2017 01:20:00 PM) (Source: MSDTC 2)(User: )
Action! (HKLM-x32\...\Mirillis Action!) (Version: 2.3.0 - Mirillis)
Adobe Creative Cloud (HKLM-x32\...\Adobe Creative Cloud) (Version: 4.1.1.202 - Adobe Systems Incorporated)
Adobe Flash Player 26 PPAPI (HKLM-x32\...\Adobe Flash Player PPAPI) (Version: 26.0.0.131 - Adobe Systems Incorporated)
Adobe Photoshop CC 2017 (HKLM-x32\...\PHSP_18_1_1) (Version: 18.1.1 - Adobe Systems Incorporated)
Adobe Premiere Pro CC 2017 (HKLM-x32\...\PPRO_11_0_0) (Version: 11.0.0 - Adobe Systems Incorporated)
AMD OverDrive (HKLM-x32\...\{EEB605FD-C5F5-4946-90F3-D65C604A9187}) (Version: 4.3.1.0698 - Advanced Micro Devices, Inc.)
Ansel (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Ansel) (Version: 384.76 - NVIDIA Corporation) Hidden
ApoDispatchConfigurator (HKLM\...\{248DD729-CDAA-4679-910C-C4D48695196A}) (Version: 2.3.1501 - Nahimic) Hidden
Asmedia USB Host Controller Driver (HKLM-x32\...\{E4FB0B39-C991-4EE7-95DD-1A1A7857D33D}) (Version: 1.16.33.1 - Asmedia Technology)
Audacity 2.1.2 (HKLM-x32\...\Audacity®_is1) (Version: 2.1.2 - Audacity Team)
AudioLaunchpadConfigurator (HKLM\...\{0330687D-5820-424E-93AC-5C06393324E3}) (Version: 2.3.1501 - Nahimic) Hidden
Autodesk Inventor Content Center Libraries 2015 (Desktop Content) (HKLM\...\{B46DECD1-1964-4EF1-0000-22D71E81877C}) (Version: 19.0.15900.0000 - Autodesk)
Autodesk Inventor Professional 2015 - English (HKLM\...\Autodesk Inventor Professional 2015) (Version: 19.0.15900.0000 - Autodesk)
Autodesk Inventor Professional 2015 (HKLM\...\{7F4DD591-1964-0001-0000-7107D70F3DB4}) (Version: 19.0.15900.0000 - Autodesk) Hidden
Autodesk Inventor Professional 2015 English Language Pack (HKLM\...\{7F4DD591-1964-0001-1033-7107D70F3DB4}) (Version: 19.0.15900.0000 - Autodesk) Hidden
Autodesk Material Library 2015 (HKLM-x32\...\{427F733F-4D6C-45BC-9324-EB743104C321}) (Version: 5.2.9.100 - Autodesk)
Autodesk Material Library Base Resolution Image Library 2015 (HKLM-x32\...\{ABE2F70B-8D94-44E9-AA04-F0DB35063D62}) (Version: 5.2.9.100 - Autodesk)
Autodesk Material Library Low Resolution Image Library 2015 (HKLM-x32\...\{4FBC9635-AC56-4378-8FDE-C4D3ED072681}) (Version: 5.2.9.100 - Autodesk)
Autodesk Revit Interoperability for Inventor 2015 (HKLM\...\{0BB716E0-1500-0210-0000-097DC2F354DF}) (Version: 15.0.166.0 - Autodesk) Hidden
Autodesk Revit Interoperability for Inventor 2015 (HKLM\...\Autodesk Revit Interoperability for Inventor 2015) (Version: 15.0.166.0 - Autodesk)
Blizzard App (HKLM-x32\...\Battle.net) (Version: - Blizzard Entertainment)
CCleaner (HKLM\...\CCleaner) (Version: 5.31 - Piriform)
CEVO CS:GO Client Beta version 2.0 (HKLM-x32\...\CEVO CS:GO Client Beta_is1) (Version: 2.0 - )
CheckDevicesConfigurator (HKLM\...\{007D3757-9892-43BD-9758-5D58F132E21B}) (Version: 2.3.1501 - Nahimic) Hidden
Configurator 360 addin (HKLM-x32\...\{8FE324B0-B934-4D68-BAB5-DE2136036237}) (Version: 19.0.11300.9000 - Autodesk, Inc.)
Counter-Strike (HKLM\...\Steam App 10) (Version: - Valve)
Counter-Strike: Condition Zero (HKLM\...\Steam App 80) (Version: - Valve)
Counter-Strike: Global Offensive (HKLM\...\Steam App 730) (Version: - Valve)
CPUID HWMonitor 1.31 (HKLM\...\CPUID HWMonitor_is1) (Version: - )
Cura 14.12 (HKLM-x32\...\Cura_14.12) (Version: - )
Cura 2.3 (HKLM-x32\...\Cura 2.3) (Version: 2.3.1 - Ultimaker)
DARK SOULS™ III (HKLM\...\Steam App 374320) (Version: - FromSoftware, Inc.)
Discord (HKCU\...\Discord) (Version: 0.0.297 - Hammer & Chisel, Inc.)
Epic Games Launcher (HKLM-x32\...\{CD8F9CE5-23D6-417E-93F0-D9A06D94E8F5}) (Version: 1.1.105.0 - Epic Games, Inc.)
Epic Games Launcher Prerequisites (x64) (HKLM\...\{66C5838F-B854-4A55-89E6-A6138747A4DF}) (Version: 1.0.0.0 - Epic Games, Inc.) Hidden
Google Chrome (HKLM-x32\...\Google Chrome) (Version: 59.0.3071.115 - Google Inc.)
Google Update Helper (HKLM-x32\...\{60EC980A-BDA2-4CB6-A427-B07A5498B4CA}) (Version: 1.3.33.5 - Google Inc.) Hidden
H1Z1: King of the Kill (HKLM\...\Steam App 433850) (Version: - Daybreak Game Company)
HI-TECH C Compiler for the PIC10/12/16 MCUs V9.82PL0 (HKLM-x32\...\PICC 9.82) (Version: 9.82 - HI-TECH Software)
HI-TECH C51-lite V9.60PL0 (HKLM-x32\...\HC51 9.60PL0) (Version: 9.60 - HI-TECH Software)
HP Officejet Pro 8610 Basic Device Software (HKLM\...\{39DA3F40-0B9E-4002-8E01-108FEC9EFE43}) (Version: 32.3.198.49673 - Hewlett-Packard Co.)
HP Officejet Pro 8610 Help (HKLM-x32\...\{F9569D00-4576-46C8-B6C7-207A4FD39745}) (Version: 32.0.0 - Hewlett Packard)
HP Update (HKLM-x32\...\{912D30CF-F39E-4B31-AD9A-123C6B794EE2}) (Version: 5.005.002.002 - Hewlett-Packard)
I.R.I.S. OCR (HKLM-x32\...\{CA6BCA2F-EDEB-408F-850B-31404BE16A61}) (Version: 12.3.4.0 - HP)
Intel(R) Network Connections 20.7.67.0 (HKLM\...\PROSetDX) (Version: 20.7.67.0 - Intel)
Inventor 2015 Heartbleed Hotfix Installer (INV19001) (HKLM\...\Autodesk Inventor Professional 2015_19001) (Version: 1 - Autodesk)
Java 8 Update 131 (HKLM-x32\...\{26A24AE4-039D-4CA4-87B4-2F32180131F0}) (Version: 8.0.1310.11 - Oracle Corporation)
Kreedz Climbing (HKLM\...\Steam App 626680) (Version: - ObsessionSoft)
Launcher Prerequisites (x64) (HKLM-x32\...\{c6c5a357-c7ca-4a5f-9789-3bb1af579253}) (Version: 1.0.0.0 - Epic Games, Inc.) Hidden
LauncherSetup (HKLM\...\{FABFAB52-3AAD-48D6-9362-C8145C2E9EC0}) (Version: 2.3.1501 - Nahimic) Hidden
League of Legends (HKLM-x32\...\{E80C09B5-A296-47E9-BD4B-BCCF2FDCA13E}) (Version: 4.1.2 - Riot Games) Hidden
League of Legends (HKLM-x32\...\League of Legends 4.1.2) (Version: 4.1.2 - Riot Games)
Logitech Gaming Software 8.91 (HKLM\...\Logitech Gaming Software) (Version: 8.91.48 - Logitech Inc.)
LogMeIn Hamachi (HKLM-x32\...\{E59194A0-A215-4C44-8B92-40780387EBE0}) (Version: 2.2.0.578 - LogMeIn, Inc.) Hidden
LogMeIn Hamachi (HKLM-x32\...\LogMeIn Hamachi) (Version: 2.2.0.578 - LogMeIn, Inc.)
Malwarebytes version 3.1.2.1733 (HKLM\...\{35065F43-4BB2-439A-BFF7-0F1014F2E0CD}_is1) (Version: 3.1.2.1733 - Malwarebytes)
Microsoft OneDrive (HKCU\...\OneDriveSetup.exe) (Version: 17.3.6917.0607 - Microsoft Corporation)
Microsoft Silverlight (HKLM\...\{89F4137D-6C26-4A84-BDB8-2E5A4BB71E00}) (Version: 5.1.41212.0 - Microsoft Corporation)
Microsoft Visual C++ 2005 Redistributable (x64) (HKLM\...\{071c9b48-7c32-4621-a0ac-3f809523288f}) (Version: 8.0.56336 - Microsoft Corporation)
Microsoft Visual C++ 2008 Redistributable - x64 9.0.30729.4148 (HKLM\...\{4B6C7001-C7D6-3710-913E-5BC23FCE91E6}) (Version: 9.0.30729.4148 - Microsoft Corporation)
Microsoft Visual C++ 2015 Redistributable (x64) - 14.0.24215 (HKLM-x32\...\{d992c12e-cab2-426f-bde3-fb8c53950b0d}) (Version: 14.0.24215.1 - Microsoft Corporation)
Microsoft Visual C++ 2015 Redistributable (x86) - 14.0.24215 (HKLM-x32\...\{e2803110-78b3-4664-a479-3611a381656a}) (Version: 14.0.24215.1 - Microsoft Corporation)
Minecraft (HKLM-x32\...\{1C16BCA3-EBC1-49F6-8623-8FBFB9CCC872}) (Version: 1.0.3.0 - Mojang)
Mockup 360 Addin 2015 (HKLM-x32\...\{E4D4242C-FC14-4B4F-B1D9-6760D8C241D5}) (Version: 1.1.0 - Autodesk)
MSI Afterburner 4.3.0 (HKLM-x32\...\Afterburner) (Version: 4.3.0 - MSI Co., LTD)
MSI Command Center (HKLM-x32\...\{85A2564E-9ED9-448A-91E4-B9211EE58A08}_is1) (Version: 1.0.1.18 - MSI)
MSI Super Charger (HKLM-x32\...\{7CDF10DD-A9B5-4DA3-AB95-E193248D4369}_is1) (Version: 1.3.0.07 - MSI)
Mumble 1.2.17 (HKLM-x32\...\{95A0093C-0C81-4D0B-BCA7-3CE11755A6BD}) (Version: 1.2.17 - Thorvald Natvig)
Mumble 1.3.0 (HKLM\...\{73E72268-8CD6-4052-A9DB-DB61577725A4}) (Version: 1.3.0 - The Mumble Developers)
Nahimic 2 (HKLM-x32\...\{f1678b8f-2de0-4c1d-826e-4614c5c900fa}) (Version: 2.3.15 - Nahimic)
Nahimic2UISetup (HKLM\...\{F99D1E2C-1123-4850-94C6-8098A29CBECD}) (Version: 2.3.1501 - Nahimic) Hidden
Notepad++ (HKLM\...\Notepad++) (Version: 7 - Notepad++ Team)
NVIDIA 3D Vision Controller Driver 369.04 (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Display.NVIRUSB) (Version: 369.04 - NVIDIA Corporation)
NVIDIA 3D Vision Driver 384.76 (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Display.3DVision) (Version: 384.76 - NVIDIA Corporation)
NVIDIA GeForce Experience 3.7.0.81 (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Display.GFExperience) (Version: 3.7.0.81 - NVIDIA Corporation)
NVIDIA Graphics Driver 384.76 (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Display.Driver) (Version: 384.76 - NVIDIA Corporation)
NVIDIA HD Audio Driver 1.3.34.27 (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_HDAudio.Driver) (Version: 1.3.34.27 - NVIDIA Corporation)
NvNodejs (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_NvNodejs) (Version: 3.7.0.81 - NVIDIA Corporation) Hidden
NvTelemetry (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_NvTelemetry) (Version: 2.6.1.0 - NVIDIA Corporation) Hidden
NvvHci (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_NvvHci) (Version: 2.02.0.5 - NVIDIA Corporation) Hidden
OBS Studio (HKLM-x32\...\OBS Studio) (Version: 18.0.1 - OBS Project)
Overwatch (HKLM-x32\...\Overwatch) (Version: - Blizzard Entertainment)
Product Improvement Study for HP Officejet Pro 8610 (HKLM\...\{D2064264-3162-4DB1-AFE0-167BEFBBCD9C}) (Version: 32.3.198.49673 - Hewlett-Packard Co.)
ProductDaemonSetup (HKLM\...\{76A9B59B-BF19-462E-B6F8-E79F57FCD54D}) (Version: 2.3.1501 - Nahimic) Hidden
ProductNSConfigurator (HKLM\...\{2289A4A1-FE3B-4A2B-BF6C-3991159EC753}) (Version: 2.3.1501 - Nahimic) Hidden
Realtek Ethernet Controller Driver (HKLM-x32\...\{8833FFB6-5B0C-4764-81AA-06DFEED9A476}) (Version: 8.47.714.2016 - Realtek)
Realtek High Definition Audio Driver (HKLM-x32\...\{F132AF7F-7BCA-4EDE-8A7C-958108FE7DBC}) (Version: 6.0.1.8105 - Realtek Semiconductor Corp.)
ROBLOX Player for Jake (HKCU\...\{373B1718-8CC5-4567-8EE2-9033AD08A680}) (Version: - ROBLOX Corporation)
Rocket League (HKLM\...\Steam App 252950) (Version: - Psyonix, Inc.)
Rockstar Games Social Club (HKLM-x32\...\Rockstar Games Social Club) (Version: 1.2.1.2 - Rockstar Games)
SHIELD Streaming (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_GFExperience.NvStreamSrv) (Version: 7.1.0380 - NVIDIA Corporation) Hidden
SonicMapperConfigurator (HKLM\...\{E5CB7DCB-63AB-4927-B66D-4866AE1D4255}) (Version: 2.3.1501 - Nahimic) Hidden
Speccy (HKLM\...\Speccy) (Version: 1.30 - Piriform)
SpeedFan (remove only) (HKLM-x32\...\SpeedFan) (Version: - )
Spotify (HKCU\...\Spotify) (Version: 1.0.58.573.g57c9cd87 - Spotify AB)
TeamSpeak 3 Client (HKLM\...\TeamSpeak 3 Client) (Version: 3.0.19 - TeamSpeak Systems GmbH)
TechPowerUp GPU-Z (HKLM-x32\...\TechPowerUp GPU-Z) (Version: - TechPowerUp)
Tom Clancy's Rainbow Six Siege (HKLM\...\Steam App 359550) (Version: - Ubisoft Montreal)
UIInstallUpgrade (HKLM\...\{4BBD5586-648B-49F8-8EC8-D2635A591DB2}) (Version: 2.3.1501 - Nahimic) Hidden
Uplay (HKLM-x32\...\Uplay) (Version: 27.0 - Ubisoft)
Visual C++ 2008 - x64 (KB958357) - v9.0.30729.177 (HKLM-x32\...\{6DA2B636-698A-3294-BF4A-B5E11B238CDD}.KB958357) (Version: 9.0.30729.177 - Microsoft Corporation)
Visual C++ 2008 - x64 (KB958357) - v9.0.30729.177 (HKLM-x32\...\{8CCEA24C-51AE-3B71-9092-7D0C44DDA2DF}.KB958357) (Version: 9.0.30729.177 - Microsoft Corporation)
Visual C++ 2008 - x64 (KB958357) - v9.0.30729.177 (HKLM-x32\...\{C3A57BB3-9AA6-3F6F-9395-6C062BDD5FC4}.KB958357) (Version: 9.0.30729.177 - Microsoft Corporation)
Visual C++ 2008 - x64 (KB958357) - v9.0.30729.177 (HKLM-x32\...\{F6F09DD8-F39B-3A16-ADB9-C9E6B56903F9}.KB958357) (Version: 9.0.30729.177 - Microsoft Corporation)
Visual C++ 2008 - x86 (KB958357) - v9.0.30729.177 (HKLM-x32\...\{04B34E21-5BEE-3D2B-8D3D-E3E80D253F64}.KB958357) (Version: 9.0.30729.177 - Microsoft Corporation)
Visual C++ 2008 - x86 (KB958357) - v9.0.30729.177 (HKLM-x32\...\{14866AAD-1F23-39AC-A62B-7091ED1ADE64}.KB958357) (Version: 9.0.30729.177 - Microsoft Corporation)
Visual C++ 2008 - x86 (KB958357) - v9.0.30729.177 (HKLM-x32\...\{4B90093A-5D9C-3956-8ABB-95848BE6EFAD}.KB958357) (Version: 9.0.30729.177 - Microsoft Corporation)
Visual C++ 2008 - x86 (KB958357) - v9.0.30729.177 (HKLM-x32\...\{B42E259C-E4D4-37F1-A1B2-EB9C4FC5A04D}.KB958357) (Version: 9.0.30729.177 - Microsoft Corporation)
Vulkan Run Time Libraries 1.0.42.1 (HKLM\...\VulkanRT1.0.42.1) (Version: 1.0.42.1 - LunarG, Inc.)
Warframe (HKLM\...\Steam App 230410) (Version: - Digital Extremes)
Windows 10 Upgrade Assistant (HKLM-x32\...\{D5C69738-B486-402E-85AC-2456D98A64E4}) (Version: 1.4.9200.22175 - Microsoft Corporation)
Windows Driver Package - Arduino LLC (www.arduino.cc) Arduino USB Driver (01/04/2013 1.0.0.0) (HKLM\...\1E3EA5624DD04BEFECF3FFF6D3A21CCE9CD70A91) (Version: 01/04/2013 1.0.0.0 - Arduino LLC (www.arduino.cc))
WinRAR 5.40 (64-bit) (HKLM\...\WinRAR archiver) (Version: 5.40.0 - win.rar GmbH)
Percentage of memory in use: 47%
Total physical RAM: 8134.94 MB
Available physical RAM: 4265.46 MB
Total Virtual: 10054.94 MB
Available Virtual: 4673.88 MB
1 Drive c: () (Fixed) (Total:465.66 GB) (Free:277.42 GB) NTFS
2 Drive d: (2nd HDD) (Fixed) (Total:465.76 GB) (Free:435.33 GB) NTFS
3 Drive e: (2TB Data) (Fixed) (Total:1863.01 GB) (Free:1740.57 GB) NTFS
User accounts for \\JAKESPC
Jake
**** End of log ****
I have comcast
Reset Internet Settings.
Download and unzip internet Flush.zip to your desktop right click it run as Administrator. Reboot the machine to apply the settings.
Hit enter after each command below.
1. Open Start and type cmd, then right-click Command Prompt and choose Run as Administrator
2. Once Command Prompt has started enter the following command. nbtstat -R
3. Wait for that command to complete, a new line will appear, now enter the following command. nbtstat -RR
4 Wait for that command to complete, a new line will appear, now enter the following command. Shutdown -r
Disable useless items.
Download easy service optmizer, save it to your desktop and unzip it there. Right click it and run as admin, then select tweaked at the bottom. Then click on the rocket, this will turn off a lot of useless items.
You will however need to change one setting. Right Click on Wlansvc — WLAN AutoConfig, then select start service, the edit service. Make sure it is automatic across the board, as per the picture.
Disable Computer Browser Service.
1. Press the Windows + R key at the same time, a Run Window will appear
2. Type or copy and paste Services.msc hit enter.
3. Scroll to the Computer Browser Service
4. Right-Click Computer Browser Service and choose Stop the service.
5. Right Click Computer Browser Service again select Properties.
6. Change the Startup type to disabled.
7. Hit Apply then Ok.
Repeat the same above to disable the Iphelper Service. Also the DNS Client Service.
Disable net bios over tcpip.
Windows key & r at the same time.
Type or copy and paste ncpa.cpl hit enter.
Right click your connection hit properties.
Select internet protocol version 4 then properties.
Select Advanced, then Wins tab.
Put a tick next to Disable Net Bios over TCPIP.
  • Download CCleaner from here.
  • After install Click Options.
  • Go to monitoring.
  • Uncheck All Monitoring items.
  • Go to advanced -- Click close program after cleaning.
  • Go to settings -- click run ccleaner when the computer starts.
  • Now that you have ccleaner installed and set-up:
  • Open the program.
  • Go to Tools
  • Go to Startup
  • Now double click each item. To Disable.
  • Leave only your antivirus enabled.
  • Then disable All items in your scheduled task as well.
  • Unless they are related to windows defender.Or your antivirus.
  • Reboot the machine.
Changing some settings.
Follow the steps here to stop your machine from communicating with other devices on your network. Click Here for instructions.
Also, go ahead and run this tool, it stops the machine from doing other things that chew bandwidth The tool is designed to stop all the telemetry.
Please report back if these steps have helped. If the issue still persist then please run the programs and post the logs. :)
