Solved Elden ring
EZKW
34
]Hey everyone, total noob question here I have (Gaming PC - HP Desktop EliteDesk 800 G1 SFF Computer PC i5 4570 3.2Ghz 16GB DDR3 RAM 1TB SSD GTX 1050 Ti Win 10 Pro WIFI with Keyboard & Mouse HAJAAN HC120) and was wondering if this would be good enough to play elden ring on if not what could I upgrade too?
Your system meets the minimum requirement for the game you should be able to on low to mid settings.
Below is a breakdown of the Elden Ring PC requirements, from the minimum to the recommended PC specs:
MINIMUM SYSTEM REQUIREMENTS
  • OS: Windows 10
  • Processor: Intel Core i5-8400 | AMD Ryzen 3 3300X
  • Memory: 12GB RAM
  • Graphics: Nvidia GeForce GTX 1060, 3GB | AMD Radeon RX 580, 4GB
  • DirectX: DirectX 12 (Feature Level 12.0)
  • Storage: 60GB
  • Sound Card: Windows-compatible audio device
RECOMMENDED SYSTEM REQUIREMENTS
  • OS: Windows 10 | Windows 11
  • Processor: Intel Core i7-8700K | AMD Ryzen 5 3600X
  • Memory: 16GB RAM
  • Graphics: Nvidia GeForce GTX 1070, 8GB | AMD Radeon RX Vega 56, 8GB
  • Storage: 60 GB
  • OS: Windows 10
  • Memory: 12GB RAM
  • Storage: 60GB
  • Memory: 16GB RAM
  • Storage: 60 GB
Okay Great I must have have misunderstood what the game required...phew... I was really looking forward to playing this game at launch thank you so much for the quick response :)
