Solved Dual Monitor Backround
Messi10ninja
21
HI,
I have a dual monitor setup. Both of my monitors are 1920 x 1080 and I'm trying to get a picture to be my wallpaper. I don't want the same picture on both monitors but one picture spread out. But the thing is that when I try to only use 1 picture for both monitors and I use the span feature in windows it zooms in too much. What should I do? Btw I can't find any higher definition pictures of the wallpaper.
Thanks in advance
in my experience, that's just what MS/Windows does, the span feature does some sort of 'auto adjust' and makes it fit accordingly.
never found a way to control that - not that I ever looked too hard, just put it down to an undesirable feature and moved on.
