DPI setting..
gary
27
43
hi, i have a 27inch monitor and to see all boxes etc.. clearly i need it to be on DPI 150% else taskbar, setting etc..are too small. the issue i have is when i set to 150% it makes certain text blurry. How do i sort this please?
Sorry but you have post on a tech forum asking for help but have provided zero information about your computer or it`s hardware, this makes it impossible for anyone to even hazard a guess as to what is going on.
Is the computer a custom build or brand name such as Dell or HP, if a brand name, provide the model name or series number (not serial) if a custom build post the brand and model name or number for the CPU, MB, the RAM ( including the amount and speed ) add on video card if one is used and the PSU (power supply unit) providing these details will enable folk to better help you.
Under Win11, there are many options to adjust.
Have you looked under Start > Settings > System > Display?
There you can tweak:
  • Scale
  • Display Resolution
  • Further option within Scale is Test Size
