Solved Does my first Pc configuration fit?
Fabiator
20
Hello,
I am assembling a new pc for the first time.
The base should be a i5 13600k.
I have already bought the i5, ssd and ram.
Now my questions:
Does the power suply fit?
Is the motherboard ok or are there better ones?
And in general do you have any suggestions for improvement?
The configuration is here: https://geizhals.de/?cat=WL-2911932
I do not click on links that I do not recognize for any reason
no information posted to make a judgement (make and model)
will give you the specific RAM that you need to run the system properly.
Are you using a graphics card make and model
What is the system going to be used for?
Size of the case.
Reactions: Fabiator
Its a german website for prize comparisan.
If you still dont want to click. Here are the specs:
SSD: Samsung SSD 970 EVO Plus 2TB
CPU: Intel Core i5-13600K
CPU-Cooler: Noctua NH-D15 chromax.black
RAM: Corsair Vengeance schwarz DIMM Kit 32GB, DDR5-5600, CL36
GPU: MSI GeForce RTX 4070 Ti Gaming Trio 12G
Mainboard: GIGABYTE Z690 Gaming X
Case: be quiet! Silent Base 802
Power Suply: be quiet! Straight Power 11 850W
The System is going to be used as a giming pc
nothing obviously alarming is sticking out at me.
should be a good rig for gaming. (y)
if I had to nit-pick anything, and budget allowing, what about upgrading the i5 to a i7 13700K or i9 13900K for the extra cores and threads and GHz.
but that i5 13600K seems to be the sweet spot on price vs grunt.
Reactions: Fabiator
