I need help with my display resolution. I have an Acer K192HQL monitor. Its resolution is 1366 x 768. When I go to display resolutions the only ones I have are 800 x 600, 1024 x 768, and 1280 x 1024 (there are like 3 more but can't use them since the input is not supported). I tried them all and they all leave big gaps on the sides of the monitor. My monitor has a setting to fill the gaps by stretching it which makes everything look bad. I've tried to update the driver but it says that the one I have is the most optimal there is. Is there anything I can do to fix this?
