Display randomly on and off
Binnoxy
41
Guys, I am completely new here. I have i5 9400, 3*8gb corsair 2400bus ram, Dell 19inch square monitor and a recent purchased 2nd hand Gigabyte RX 580 gpu. Without connecting my gpu, everything goes fine. But when i connect gpu in my monitor with converter cable, it goes randomly screen on and off problem. I have no idea what to do now
So when you plug in the monitor to the mobo it works and not with the gpu.. Could be a gpu issue also did you install the drivers for the gpu ?
yes I did. I think you have noticed, my CPU is on. But, the problem remains in display. Thanks
Good chance it is faulty gpu and that is why it was sold.
You have not supplied your power supply info.
Make, Model, Wattage.
An under supplied power supply can cause trouble.
  • Upon Completion:
  • Hit File
  • Publish Snap Shot
Nothing in the speccy report can be used by anyone to hack your computer.
The speccy report will NOT give us your power supply details.
Closing – no activity.
