Desktop not building correctly
Sargan
8
67
About 50% of the time when I book up W10, almost all desktop icons are just white ... and PC shows as busy.
No matter how long I leave it does not recover.
If I use Ctl_Alt_Del and log off, then log back on it does build properly.
I have also carried out right-click Refresh on a correctly built desktop, but the fault still happening.
Any suggestions .... it's running Windows 10 ver 21H1
Is there a repair/rebuild option ?
Complete system specs including the PSU make and model.
Run System File Checker
Run a Check Disk
to post the results
Press the Windows + R keys to open the Run dialog
Type powershell.exe
Then press Enter.
In PowerShell, copy and paste the command below, and press Enter.
get-winevent -FilterHashTable @{logname="Application"; id="1001"}| ?{$_.providername –match "wininit"} | fl timecreated, message | out-file Desktop\CHKDSKResults.txt
The CHKDSKResults.txt file will be created on your desktop,
COPY and PASTE the contents from the CHKDSKResults.txt file into a post. You can also attach the files.
System spec ....
Intel i5-3570 3.4GHz
16 GB RAM Corsair XMS
OS 64 bit
Motherboard ASUS P8Z77-V LE
MSI NVIDIA GeForce GTX560 TI Graphics card
SSD primary drive 500GB
HDD secondaries 2TB
Run DISM.exe /Online /Cleanup-image /Restorehealth
Run SFC /scannow CBS log attached
Run chkdsk C: /F /R
It completed but when I run your command in power shell gives error ... " Could not find a part of the path 'C:\WINDOWS\system32\Desktop\CHKDSKResults.txt'."
Did you miss
When you press the Windows Key + X does it show Powershell or Command Prompt
If Powershel use the one that shows Admin and copy and paste the command again see if that does it.
Did the SFC state any errors on the screen?
I tried your command several; times in Popwershell Admin .... same error.
I usd this string instead" get-winevent -FilterHashTable @{logname="Application"; id="1001"}| ?{$_.providername -match "wininit"} | fl timecreated, message | out-file "$env:userprofile\Desktop\CHKDSKResults.txt""
This worked OK .... file is attached.
Power Supply is CoolerMaster M2 Silent Pro 620W
In addition, standard CPU fan replaced with CoolerMaster Hyper
