Solved DELL VOSTRO 320 SOLID AMBER POWER BUTTON
Jerry Uttley
53
Hi all. AND Thanks for reading. Normally the power button remains solid white. This could be a power supply issue. i'll also replace the CMOS battery. Any suggestions?
With Dell if the power indicator is amber in color means that there is a power issue usually due to the power supply failing.
Check all of the power connections if that does not help then replace the power supply.
  • Disconnect any external peripherals (flash drives, printers, external hard drives) from the computer including the power supply.
  • Press and hold the power button for 20 seconds.
  • Reconnect the power supply. Try to restart the computer and check.
If that doesn't work, your power brick might be fried
Thanks much for comments. it was time for a new one. The Vostro was on its way, previous problem. But thanks again!
