"D" key on keyboard sometimes does not work.
Funningur
24
Hi,
My "D" key has it's own life. Sometimes it does not respond other times it puts in an extra "dd" like that. And other times it works fine.
Example: "ddon't use the laddder it oesn't work"
I have tried to remove the keycap and clean under it. It is now clean and i can't see anything wrong with it. but I'm no expert. It looks just like the other keys.
hope you can help me.
Try using a USB keyboard.
Have you tried cleaning the entire keyboard?
With system turned off gently rub your hand over the keyboard with the system upside down a few times.
(Remove the power cord and battery if its can be)
Put the system on its side and use some compressed air to blow any left over stuff out and follow the instructions on the can
The the system have any warranty if so make a claim .
how old is the keyboard?
any spills in the past???
but.... they do die, no all that common, but not unheard of either.
could be time to treat yourself to a new one. :)
