Hi everyone.
I need help... I am confused with different readings from monitoring my CPU temp.
I tried to find an answer in various forums but only got more confused, can someone explain in a simple way the difference in the following please ?
HWINFO64 gives me these readings:
(CPU Section) CPU [#0]: AMD Athlon X4 880k
CPU package (TSI) 73 degrees (very unstable readings jumping from anything between 50 to 90 degrees on some occasions)
(MB section) Asus A88XM-PLUS
CPU 40 degrees (stable slow increase, degrease (36-37 in total idle mode)
My AMD AI suite III gives me the same as HWINFO on the MB reading (40 at the moment of writing this (Semi-idle state, ie. browser open))
If I use Speccy I get an other very high erratic reading between 60 to 95 degrees.
What should I make of this and what is the correct temp for my CPU ?
Can anyone clarify this for me pls?
