Hello, I'm having trouble with my new pc
Specs:
Ryzen 5 3600
MSI b450 mortar max
Gainward RTX 3060 ghost
Crucial Ballistics 16 gb 3200
EVGA 600 w2
Its a prebuild that i won in a tournament, and that after some days of use, refused to turn on. I sent it back to the shop that gave it to me and they changed the CPU and RAM.
After that, the same thing happened and Im really starting to get really stressed cause I really can't figure out what component is causing the issue. I don't think its the BIOS because the pc worked fine before hand.
Quick note, while waiting for the pick up truck before sending it back, the pc turned on fine after 2 days of not using it. It has been 2 months of trouble shooting and im kinda fed up with this system at the moment.
What confuses me the most is that it works fine for some time and then it dies.
The GPU is also fine and i suspect its the motherboard or the PSU.
Let me know what u think.
Specs:
Ryzen 5 3600
MSI b450 mortar max
EVGA 600 w2
