connecting earpods to pc
luxodiy
25
Good day. That was the problem. I bought 3.5mm headphones and connected them to my computer with a headset splitter. The sound is good, but the problem with the microphone, it emits a constant squeak instead of sound. The microphone itself works, tested on 3 devices (xiaomi smartphone, Dell laptop and computer with an old motherboard). My gigabyte 970a-ds3p motherboard. Has anyone encountered such a problem? If so, tell me what to do.
english forum, use this, I translated your original post.
forget the splitter for now, let's just see if we can get them working properly.
plug the headset into the back audio ports, headphones go into the green port, microphone into the pink.
