Computer turns on wont display on monitor
Jordankj350
31
I've had ky computer for a few months now. It's not super old. I'm not really knowledgeable on pcs but I'm trying to learn. My computer started to turn on and then turn off repeatedly because the power button was stuck, now it wont display on the monitor and I dont think its recognizing any of my plug ins because the k+m dont light up
can you give us your computers specs?
what have you tried so far?
describe what is happening when you try to turn it on - do lights come on, fans spin, hard drive noises?
Prime z730-p mother board
Intel i7 6 core
Nvidia gtx 1070
I've checked all the cords, plugged and unplugged everything. I plugged the hdmi into the basic graphics card and still nothing. Reset the bios. Switched monitors also
if you had the GTX1070 plugged in, the basic graphics port on the mobo will be disabled, remove the GTX and try again.
also remove and clean the memory chips and their mobo slots with a soft bristle brush.
insert one chip and try that.
