Hello! As of recent whenever I would play WoW or Genshin (especially when watching something on the other monitor), my computer would freeze and loop audio/buzz, and force me to restart to get out of it. And now even without watching or running anything else, Overwatch seems to cause crashing.
So far I've updated all my drivers, ran Windows' memory diagnostics with no detected errors, fixed my hard drives using Windows' internal optimizing tools, and uninstalled and reinstalled HD Realtek drivers. And it still happens (with the exception of the last two crashes today not having an audio loop (though nothing much as going on audio wise anyway).
Would much appreciate some insight!
Here's the speccy logs: http://speccy.piriform.com/results/6YP1pFYlwWvpjdLfG0IisVG
And here's the MiniToolBox logs:
MiniToolBox by Farbar Version: 13-05-2022 Ran by Carlos (administrator) on 18-05-2022 at 20:26:31 Running from "D:\Library" Microsoft Windows 10 Home (X64) Model: MS-7B85 Manufacturer: Micro-Star International Co., Ltd. Boot Mode: Normal *************************************************************************** ========================= Event log errors: =============================== Application errors: ================== Error: (05/18/2022 08:15:58 PM) (Source: Bonjour Service) (EventID: 100) (User: ) Description: mDNSCoreReceiveResponse: Unexpected conflict discarding 25 4.C.7.8.1.3.8.F.E.E.5.A.B.9.0.C.0.0.0.0.0.0.0.0.0.0.0.0.0.8.E.F.ip6.arpa. PTR TonyComputeroni-2.local. Error: (05/18/2022 08:15:58 PM) (Source: Bonjour Service) (EventID: 100) (User: ) Description: mDNSCoreReceiveResponse: Received from 192.168.1.232:5353 23 4.C.7.8.1.3.8.F.E.E.5.A.B.9.0.C.0.0.0.0.0.0.0.0.0.0.0.0.0.8.E.F.ip6.arpa. PTR TonyComputeroni.local. Error: (05/18/2022 08:15:58 PM) (Source: Bonjour Service) (EventID: 100) (User: ) Description: mDNSCoreReceiveResponse: Unexpected conflict discarding 25 4.1.9.1.3.6.0.E.4.0.6.3.1.3.1.B.0.5.1.9.0.6.2.4.0.0.7.1.0.0.6.2.ip6.arpa. PTR TonyComputeroni-2.local. Error: (05/18/2022 08:15:58 PM) (Source: Bonjour Service) (EventID: 100) (User: ) Description: mDNSCoreReceiveResponse: Received from 192.168.1.232:5353 23 4.1.9.1.3.6.0.E.4.0.6.3.1.3.1.B.0.5.1.9.0.6.2.4.0.0.7.1.0.0.6.2.ip6.arpa. PTR TonyComputeroni.local. Error: (05/18/2022 08:15:58 PM) (Source: Bonjour Service) (EventID: 100) (User: ) Description: mDNSCoreReceiveResponse: Unexpected conflict discarding 25 4.C.7.8.1.3.8.F.E.E.5.A.B.9.0.C.0.5.1.9.0.6.2.4.0.0.7.1.0.0.6.2.ip6.arpa. PTR TonyComputeroni-2.local. Error: (05/18/2022 08:15:58 PM) (Source: Bonjour Service) (EventID: 100) (User: ) Description: mDNSCoreReceiveResponse: Received from 192.168.1.232:5353 23 4.C.7.8.1.3.8.F.E.E.5.A.B.9.0.C.0.5.1.9.0.6.2.4.0.0.7.1.0.0.6.2.ip6.arpa. PTR TonyComputeroni.local. Error: (05/18/2022 08:15:58 PM) (Source: Bonjour Service) (EventID: 100) (User: ) Description: mDNSCoreReceiveResponse: Unexpected conflict discarding 25 232.1.168.192.in-addr.arpa. PTR TonyComputeroni-2.local. Error: (05/18/2022 08:15:58 PM) (Source: Bonjour Service) (EventID: 100) (User: ) Description: mDNSCoreReceiveResponse: Received from 192.168.1.232:5353 23 232.1.168.192.in-addr.arpa. PTR TonyComputeroni.local. Error: (05/18/2022 08:15:39 PM) (Source: Bonjour Service) (EventID: 100) (User: ) Description: Local Hostname TonyComputeroni.local already in use; will try TonyComputeroni-2.local instead Error: (05/18/2022 08:15:39 PM) (Source: Bonjour Service) (EventID: 100) (User: ) Description: mDNSCoreReceiveResponse: ProbeCount 2; will deregister 4 TonyComputeroni.local. Addr 192.168.1.232 System errors: ============= Error: (05/18/2022 08:15:30 PM) (Source: volmgr) (EventID: 161) (User: ) Description: Dump file creation failed due to error during dump creation. Error: (05/18/2022 08:15:38 PM) (Source: EventLog) (EventID: 6008) (User: ) Description: The previous system shutdown at 8:10:44 PM on 5/18/2022 was unexpected. Error: (05/18/2022 07:30:51 PM) (Source: NetBT) (EventID: 4311) (User: ) Description: Initialization failed because the driver device could not be created. Use the string "%2" to identify the interface for which initialization failed. It represents the MAC address of the failed interface or the Globally Unique Interface Identifier (GUID) if NetBT was unable to map from GUID to MAC address. If neither the MAC address nor the GUID were available, the string represents a cluster device name. Error: (05/18/2022 07:30:51 PM) (Source: NetBT) (EventID: 4311) (User: ) Description: Initialization failed because the driver device could not be created. Use the string "%2" to identify the interface for which initialization failed. It represents the MAC address of the failed interface or the Globally Unique Interface Identifier (GUID) if NetBT was unable to map from GUID to MAC address. If neither the MAC address nor the GUID were available, the string represents a cluster device name. Error: (05/18/2022 07:30:44 PM) (Source: EventLog) (EventID: 6008) (User: ) Description: The previous system shutdown at 7:06:28 PM on 5/18/2022 was unexpected. Error: (05/18/2022 01:33:25 PM) (Source: Schannel) (EventID: 4103) (User: NT AUTHORITY) Description: A fatal error occurred while creating a TLS client credential. The internal error state is 10013. Error: (05/18/2022 01:27:09 PM) (Source: disk) (EventID: 7) (User: ) Description: The device, \Device\Harddisk1\DR1, has a bad block. Error: (05/18/2022 01:27:04 PM) (Source: disk) (EventID: 7) (User: ) Description: The device, \Device\Harddisk1\DR1, has a bad block. Error: (05/18/2022 01:27:00 PM) (Source: disk) (EventID: 7) (User: ) Description: The device, \Device\Harddisk1\DR1, has a bad block. Error: (05/18/2022 01:26:55 PM) (Source: disk) (EventID: 7) (User: ) Description: The device, \Device\Harddisk1\DR1, has a bad block. Windows Defender: ================ Date: 2022-05-09 16:04:36 Description: Microsoft Defender Antivirus scan has been stopped before completion. Scan Type: Antimalware Scan Parameters: Quick Scan Date: 2022-05-09 14:01:19 Description: Microsoft Defender Antivirus scan has been stopped before completion. Scan Type: Antimalware Scan Parameters: Quick Scan Date: 2022-05-02 15:54:38 Description: Microsoft Defender Antivirus scan has been stopped before completion. Scan Type: Antimalware Scan Parameters: Quick Scan Date: 2022-04-29 17:03:55 Description: Microsoft Defender Antivirus scan has been stopped before completion. Scan Type: Antimalware Scan Parameters: Quick Scan Date: 2022-04-29 15:33:40 Description: Microsoft Defender Antivirus scan has been stopped before completion. Scan Type: Antimalware Scan Parameters: Quick Scan CodeIntegrity Errors: ==================== Date: 2022-05-18 20:25:49 Description: Code Integrity determined that a process (\Device\HarddiskVolume4\Windows\System32\svchost.exe) attempted to load \Device\HarddiskVolume4\Program Files\Bonjour\mdnsNSP.dll that did not meet the Microsoft signing level requirements. Date: 2022-05-18 20:25:44 Description: Code Integrity determined that a process (\Device\HarddiskVolume4\Windows\System32\svchost.exe) attempted to load \Device\HarddiskVolume4\Program Files\Bonjour\mdnsNSP.dll that did not meet the Windows signing level requirements. =========================== Installed Programs ============================ abrMate version 1.0 (HKLM-x32\...\abrMate_is1) (Version: 1.0 - ) ACID Music Studio 11.0 (x64) (HKLM\...\{18B870B0-1AA8-11EA-BD3A-001B21B1DCED}) (Version: 11.0.10.21 - MAGIX) AMD Ryzen Master SDK (HKLM\...\{DBD50508-5F75-416B-995D-C42433A00944}) (Version: 2.7.0.1725 - Advanced Micro Devices, Inc.) AMD_Chipset_Drivers (HKLM-x32\...\{cf77cf6b-71ff-4a71-802d-43adb9b271b7}) (Version: 3.10.22.706 - Advanced Micro Devices, Inc.) Hidden Apple Application Support (HKLM-x32\...\{46F044A5-CE8B-4196-984E-5BD6525E361D}) (Version: 2.3.6 - Apple Inc.) Apple Software Update (HKLM-x32\...\{789A5B64-9DD9-4BA5-915A-F0FC0A1B7BFE}) (Version: 2.1.3.127 - Apple Inc.) Aseprite (HKLM\...\Steam App 431730) (Version: - David Capello) ASTRONEER (HKLM\...\Steam App 361420) (Version: - System Era Softworks) Avast Secure Browser (HKLM-x32\...\Avast Secure Browser) (Version: 101.0.16219.55 - AVAST Software) Avast Update Helper (HKLM-x32\...\{19C3AB22-3718-4E4D-B203-242F5001565B}) (Version: 1.8.1189.1 - AVAST Software) Hidden Battle.net (HKLM-x32\...\Battle.net) (Version: - Blizzard Entertainment) Bloons TD 6 (HKLM\...\Steam App 960090) (Version: - Ninja Kiwi) Bonjour (HKLM\...\{56DDDFB8-7F79-4480-89D5-25E1F52AB28F}) (Version: 3.1.0.1 - Apple Inc.) Brave (HKLM-x32\...\BraveSoftware Brave-Browser) (Version: 101.1.38.119 - Brave Software Inc) Burning Crusade Classic (HKLM-x32\...\Burning Crusade Classic) (Version: - Blizzard Entertainment) Canon Easy-WebPrint EX (HKLM-x32\...\Easy-WebPrint EX) (Version: 1.7.0.0 - Canon Inc.) Canon IJ Network Scanner Selector EX (HKLM-x32\...\Canon_IJ_Network_Scanner_Selector_EX) (Version: 1.5.4.4 - Canon Inc.) Canon IJ Network Tool (HKLM-x32\...\Canon_IJ_Network_UTILITY) (Version: 3.7.0 - Canon Inc.) Canon IJ Scan Utility (HKLM-x32\...\Canon_IJ_Scan_Utility) (Version: 1.1.20.13 - Canon Inc.) Canon Inkjet Printer/Scanner/Fax Extended Survey Program (HKLM-x32\...\CANONIJPLM100) (Version: 6.4.0 - Canon Inc.) Canon MG3600 series MP Drivers (HKLM\...\{1199FAD5-9546-44f3-81CF-FFDB8040B7BF}_Canon_MG3600_series) (Version: 1.00 - Canon Inc.) Canon MG3600 series User Registration (HKLM-x32\...\Canon MG3600 series User Registration) (Version: - Canon Inc.) Canon My Image Garden (HKLM-x32\...\Canon My Image Garden) (Version: 3.6.4 - Canon Inc.) Canon My Image Garden Design Files (HKLM-x32\...\Canon My Image Garden Design Files) (Version: 3.6.0 - Canon Inc.) Canon Quick Menu (HKLM-x32\...\CanonQuickMenu) (Version: 2.8.5 - Canon Inc.) cFosSpeed 12.01 (HKLM\...\cFosSpeed) (Version: 12.01 - cFos Software GmbH, Bonn) CLIP STUDIO 1.11.14 (HKLM-x32\...\{49274EB8-4598-47E6-8039-9BB7CE07627E}) (Version: 1.11.14 - CELSYS) CLIP STUDIO PAINT 1.11.14 (HKLM-x32\...\{1E4572D2-28BC-4BC9-B743-13DC6CFD71DB}) (Version: 1.11.14 - CELSYS) CORSAIR iCUE Software (HKLM-x32\...\{5A44EF1D-12EE-43D7-9CAB-535F377C8D46}) (Version: 3.38.88 - Corsair) Counter-Strike: Source (HKLM\...\Steam App 240) (Version: - Valve) Documentation Manager (HKLM\...\{E80BFF97-B9A6-41B6-8686-7A7CC235AB91}) (Version: 22.100.1.1 - Intel Corporation) Hidden Don't Starve Together (HKLM\...\Steam App 322330) (Version: - Klei Entertainment) EA app (HKLM\...\{C2622085-ABD2-49E5-8AB9-D3D6A642C091}) (Version: 12.0.213.5170 - Electronic Arts) Hidden EA app (HKLM-x32\...\{8ea85847-aa44-4f36-8095-162037a6f8d7}) (Version: 12.0.213.5170 - Electronic Arts) ENE RGB HAL (HKLM\...\{8DA1B230-D82E-4A24-9237-363E2E1E2695}) (Version: 1.0.21.0 - Ene Tech.) Hidden ENE RGB HAL (HKLM-x32\...\{bb670f8d-3d66-4f36-8e60-02b71bb0a4e9}) (Version: 1.0.21.0 - Ene Tech.) Hidden Everything 1.4.1.988 (x64) (HKLM\...\Everything) (Version: 1.4.1.988 - David Carpenter) FTL: Faster Than Light (HKLM\...\Steam App 212680) (Version: - Subset Games) GameInput Redistributable (HKLM-x32\...\{7E52156F-18FE-B953-BEA9-6BE6A77AFDFF}) (Version: 10.1.19041.3906 - Microsoft Corporation) Garry's Mod (HKLM\...\Steam App 4000) (Version: - Facepunch Studios) Genshin Impact (HKLM\...\Genshin Impact Beta) (Version: 2.3.3.0 - miHoYo Co.,Ltd) Google Chrome (HKLM-x32\...\Google Chrome) (Version: 101.0.4951.67 - Google LLC) Google Update Helper (HKLM-x32\...\{A92DAB39-4E2C-4304-9AB6-BC44E68B55E2}) (Version: 1.3.99.0 - Google Inc.) Hidden Grand Theft Auto V (HKLM\...\Steam App 271590) (Version: - Rockstar North) Halo: The Master Chief Collection - INSIDER (HKLM\...\Steam App 1064280) (Version: - ) House Flipper (HKLM\...\Steam App 613100) (Version: - Empyrean) Intel(R) C++ Redistributables on Intel(R) 64 (HKLM-x32\...\{F70BCE36-25F2-4475-A918-6209B3D85BF3}) (Version: 15.0.179 - Intel Corporation) Intel(R) Network Connections 26.2.0.1 (HKLM\...\PROSetDX) (Version: 26.2.0.1 - Intel) Intel(R) Wireless Bluetooth(R) (HKLM-x32\...\{00004090-0220-1033-84C8-B8D95FA3C8C3}) (Version: 22.90.4.1 - Intel Corporation) Intel® Software Installer (HKLM-x32\...\{021cf0ff-212e-4f4c-ae1a-c292b13604fb}) (Version: 22.100.1.1 - Intel Corporation) Hidden Intel® Software Installer (HKLM-x32\...\{69d361f9-6cce-41a7-b82c-2d1e4be7e32f}) (Version: 22.0.0.6 - Intel Corporation) Hidden Intel® Software Installer (HKLM-x32\...\{cc2553fe-0c12-40bb-8d08-969eacd8c686}) (Version: 22.40.0.7 - Intel Corporation) Hidden Intel® Software Installer (HKLM-x32\...\{f5ff138d-570c-4b07-ae54-a9b491619e60}) (Version: 22.70.0.6 - Intel Corporation) Hidden Java(TM) SE Development Kit 17.0.1 (64-bit) (HKLM\...\{7ECAAC8F-FBBE-5265-BBF4-0AC48139FB26}) (Version: 17.0.1.0 - Oracle Corporation) Lightshot-5.5.0.7 (HKLM-x32\...\{30A5B3C9-2084-4063-A32A-628A98DE512B}_is1) (Version: 5.5.0.7 - Skillbrains) Magic Bullet Suite (HKLM\...\Magic Bullet Suite v14.0.4) (Version: - Red Giant LLC) Magic Bullet Suite (HKLM\...\Magic Bullet Suite v15.1.0) (Version: - Maxon Computer GmbH) MakeMKV v1.15.4 (HKLM-x32\...\MakeMKV) (Version: v1.15.4 - GuinpinSoft inc) Maxon Cinema 4D 24 (HKLM\...\Maxon Cinema 4D S24) (Version: S24 - Maxon) Maxon Cinema 4D 25 (HKLM\...\Maxon Cinema 4D R25) (Version: R25 - Maxon) Microsoft 365 Apps for enterprise - en-us (HKLM\...\O365ProPlusRetail - en-us) (Version: 16.0.15128.20224 - Microsoft Corporation) Microsoft Update Health Tools (HKLM\...\{7B1FCD52-8F6B-4F12-A143-361EA39F5E7C}) (Version: 3.67.0.0 - Microsoft Corporation) Microsoft Visual C++ 2008 Redistributable - x64 9.0.30729.6161 (HKLM\...\{5FCE6D76-F5DC-37AB-B2B8-22AB8CEDB1D4}) (Version: 9.0.30729.6161 - Microsoft Corporation) Microsoft Visual C++ 2010 x64 Redistributable - 10.0.40219 (HKLM\...\{1D8E6291-B0D5-35EC-8441-6616F567A0F7}) (Version: 10.0.40219 - Microsoft Corporation) MIDI-OX (HKLM-x32\...\{A6457851-5EA9-45B0-AF1D-D2A0A4781CFB}) (Version: 7.02.372 - MIDIOX Computing) Minecraft Launcher (HKLM-x32\...\{F6678473-0198-46D0-A88F-2A247E6FA03C}) (Version: 1.0.0.0 - Mojang) Mozilla Firefox (x64 en-US) (HKLM\...\Mozilla Firefox 100.0.1 (x64 en-US)) (Version: 100.0.1 - Mozilla) Mozilla Maintenance Service (HKLM\...\MozillaMaintenanceService) (Version: 79.0 - Mozilla) MSI Afterburner 4.6.2 (HKLM-x32\...\Afterburner) (Version: 4.6.2 - MSI Co., LTD) MSI SDK (HKLM-x32\...\{EE7D557C-3AE7-4348-8DCA-3A89790D0002}}_is1) (Version: 2.2021.1110.01 - MSI) Newgrounds Player (HKLM-x32\...\{B9735123-2823-49F8-8264-372895D39702}) (Version: 1.0.0 - Newgrounds) NVIDIA FrameView SDK 1.2.7521.31103277 (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_FrameViewSdk) (Version: 1.2.7521.31103277 - NVIDIA Corporation) NVIDIA GeForce Experience 3.25.1.27 (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Display.GFExperience) (Version: 3.25.1.27 - NVIDIA Corporation) NVIDIA Graphics Driver 512.59 (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Display.Driver) (Version: 512.59 - NVIDIA Corporation) NVIDIA HD Audio Driver 1.3.39.3 (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_HDAudio.Driver) (Version: 1.3.39.3 - NVIDIA Corporation) NVIDIA PhysX System Software 9.21.0713 (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Display.PhysX) (Version: 9.21.0713 - NVIDIA Corporation) NVIDIA USBC Driver 1.46.831.832 (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_USBC) (Version: 1.46.831.832 - NVIDIA Corporation) Oddworld: Abe's Exoddus (HKLM\...\Steam App 15710) (Version: - Oddworld Inhabitants) Oddworld: Abe's Oddysee (HKLM\...\Steam App 15700) (Version: - Oddworld Inhabitants) Oddworld: Munch's Oddysee (HKLM\...\Steam App 15740) (Version: - Oddworld Inhabitants) Oddworld: New 'n' Tasty (HKLM\...\Steam App 314660) (Version: - Just Add Water (Developments), Ltd.) Oddworld: Stranger's Wrath HD (HKLM\...\Steam App 15750) (Version: - Oddworld Inhabitants) Office 16 Click-to-Run Extensibility Component (HKLM\...\{90160000-008C-0000-1000-0000000FF1CE}) (Version: 16.0.15128.20146 - Microsoft Corporation) Hidden Office 16 Click-to-Run Licensing Component (HKLM\...\{90160000-007E-0000-1000-0000000FF1CE}) (Version: 16.0.15128.20224 - Microsoft Corporation) Hidden Office 16 Click-to-Run Localization Component (HKLM\...\{90160000-008C-0409-1000-0000000FF1CE}) (Version: 16.0.14131.20278 - Microsoft Corporation) Hidden Overwatch (HKLM-x32\...\Overwatch) (Version: - Blizzard Entertainment) Overwolf (HKLM-x32\...\Overwolf) (Version: 0.198.0.11 - Overwolf Ltd.) Paradox Launcher v2 (HKLM\...\{66DA3501-823A-4F07-A20D-C64495A59DC8}) (Version: 2.1.0 - Paradox Interactive) Parsec (HKLM-x32\...\Parsec) (Version: 150-81 - Parsec Cloud Inc.) Peggle Deluxe (HKLM\...\Steam App 3480) (Version: - PopCap Games, Inc.) Pentablet version 3.2.2.211028 (HKLM\...\{5DAB8C1A-6D8E-467D-BE62-AC13087AA950}_is1) (Version: 3.2.2.211028 - XP-PEN Technology) Promontory_GPIO Driver (HKLM-x32\...\{B5512BCC-F4CD-4159-86A4-B2AD7D38FFA9}) (Version: 2.0.1.0 - Advanced Micro Devices, Inc.) Hidden PureRef (HKLM-x32\...\PureRef) (Version: 1.11.1 - Idyllic Pixel) Python 3.7.0 Core Interpreter (64-bit) (HKLM\...\{F046BD5A-33F4-4ABA-BD2D-0227F6291EC9}) (Version: 3.7.150.0 - Python Software Foundation) Hidden Python 3.7.0 Development Libraries (64-bit) (HKLM\...\{61246987-8D99-44A9-8FF5-E2E3F503B72D}) (Version: 3.7.150.0 - Python Software Foundation) Hidden Python 3.7.0 Documentation (64-bit) (HKLM\...\{E7C56E72-C80E-453B-9345-FAEAE5DB51A4}) (Version: 3.7.150.0 - Python Software Foundation) Hidden Python 3.7.0 Executables (64-bit) (HKLM\...\{84B7971A-F59F-4247-AD34-BEC02CF85FBD}) (Version: 3.7.150.0 - Python Software Foundation) Hidden Python 3.7.0 pip Bootstrap (64-bit) (HKLM\...\{8A6F7991-1955-4C46-8C0C-8D7C6F7042FA}) (Version: 3.7.150.0 - Python Software Foundation) Hidden Python 3.7.0 Standard Library (64-bit) (HKLM\...\{18D93BBC-06F6-449D-96FB-CD473CFC6A6D}) (Version: 3.7.150.0 - Python Software Foundation) Hidden Python 3.7.0 Tcl/Tk Support (64-bit) (HKLM\...\{A2FC01E0-059E-4D21-AFD2-B63A7E1EF3CD}) (Version: 3.7.150.0 - Python Software Foundation) Hidden Python 3.7.0 Test Suite (64-bit) (HKLM\...\{E4266358-1C9B-4AF0-ABF7-72BE136904CF}) (Version: 3.7.150.0 - Python Software Foundation) Hidden Python 3.7.0 Utility Scripts (64-bit) (HKLM\...\{9E24E01B-CBD8-4558-A56D-6188F1A3C822}) (Version: 3.7.150.0 - Python Software Foundation) Hidden Python Launcher (HKLM-x32\...\{D6BDDB48-938A-4384-A7BE-2B4E4931B111}) (Version: 3.7.6386.0 - Python Software Foundation) QuickTime 7 (HKLM-x32\...\{FF59BD75-466A-4D5A-AD23-AAD87C5FD44C}) (Version: 7.79.80.95 - Apple Inc.) Raft (HKLM\...\Steam App 648800) (Version: - Redbeet Interactive) Realtek Audio Driver (HKLM-x32\...\{F132AF7F-7BCA-4EDE-8A7C-958108FE7DBC}) (Version: 6.0.9336.1 - Realtek Semiconductor Corp.) Rockstar Games Launcher (HKLM-x32\...\Rockstar Games Launcher) (Version: 1.0.57.785 - Rockstar Games) Rockstar Games Social Club (HKLM-x32\...\Rockstar Games Social Club) (Version: 2.1.3.2 - Rockstar Games) Rogue Legacy 2 (HKLM\...\Steam App 1253920) (Version: - Cellar Door Games) Rune Factory 4 Special (HKLM\...\Steam App 1580240) (Version: - Marvelous Inc.) Sid Meier's Civilization V (HKLM\...\Steam App 8930) (Version: - Firaxis Games) Sid Meier's Civilization: Beyond Earth (HKLM\...\Steam App 65980) (Version: - Firaxis Games) SoulseekQt version 2019.7.22 (HKLM-x32\...\{8A4E1646-488C-4E5B-AC31-F784400E8D2D}_is1) (Version: 2019.7.22 - Soulseek LLC) Steam (HKLM-x32\...\Steam) (Version: 2.10.91.91 - Valve Corporation) Swivel (HKLM-x32\...\Swivel) (Version: 1.11 - Newgrounds.com, Inc.) Team Fortress 2 (HKLM\...\Steam App 440) (Version: - Valve) Teams Machine-Wide Installer (HKLM-x32\...\{731F6BAA-A986-45A4-8936-7C3AAAAA760B}) (Version: 1.3.0.13565 - Microsoft Corporation) The Binding of Isaac: Rebirth (HKLM\...\Steam App 250900) (Version: - Nicalis, Inc.) The Elder Scrolls II: Daggerfall (HKLM\...\Steam App 1812390) (Version: - Bethesda Softworks) The Elder Scrolls V: Skyrim Special Edition (HKLM\...\Steam App 489830) (Version: - Bethesda Game Studios) The Forest (HKLM\...\Steam App 242760) (Version: - Endnight Games Ltd) The Sims 3 (HKLM-x32\...\The Sims 3_is1) (Version: - ) Toon Boom Harmony 21 Advanced (HKLM-x32\...\{8B83B458-71BD-1014-9667-BCFC9FCDC13C}) (Version: 21.0.1.17727 - Toon Boom Animation) Toon Boom Storyboard Pro 20 (HKLM-x32\...\{C39B335A-751A-1014-8B71-4EF39FCDC13C}) (Version: 20.10.0.16510 - Toon Boom Animation) Tower Unite (HKLM\...\Steam App 394690) (Version: - PixelTail Games) TradeSkillMaster Application version 1.0 (HKLM-x32\...\{c44da794-b956-4d50-8733-346d56ae63c7}_is1) (Version: 1.0 - TradeSkillMaster) Update Notifier (HKLM\...\{67B5D9F1-3A83-4502-835C-17F758EF1CCF}) (Version: 3.0.0.50 - MAGIX Software GmbH) Hidden Update Notifier (HKLM\...\MX.{67B5D9F1-3A83-4502-835C-17F758EF1CCF}) (Version: 3.0.0.50 - MAGIX Software GmbH) UXP WebView Support (HKLM-x32\...\UXPW_1_1_0) (Version: 1.1.0 - Adobe Inc.) ViGEm Bus Driver (HKLM\...\{4030BA52-E312-462E-B020-CCB5A2AC5497}) (Version: 1.16.116 - Nefarius Software Solutions e.U.) VLC media player (HKLM\...\VLC media player) (Version: 3.0.12 - VideoLAN) Vortex (HKLM\...\57979c68-f490-55b8-8fed-8b017a5af2fe) (Version: 1.5.10 - Black Tree Gaming Ltd.) VRChat (HKLM\...\Steam App 438100) (Version: - VRChat Inc.) Windows PC Health Check (HKLM\...\{6798C408-2636-448C-8AC6-F4E341102D27}) (Version: 3.6.2204.08001 - Microsoft Corporation) WinRAR 6.00 beta 2 (64-bit) (HKLM\...\WinRAR archiver) (Version: 6.00.2 - win.rar GmbH) World of Warcraft (HKLM-x32\...\World of Warcraft) (Version: - Blizzard Entertainment) World of Warcraft Classic Era (HKLM-x32\...\World of Warcraft Classic Era) (Version: - Blizzard Entertainment) Packages: ========= Acrobat Notification Client -> C:\Program Files\WindowsApps\AcrobatNotificationClient_1.0.4.0_x86__e1rzdqpraam7r [2020-08-01] (Adobe Systems Incorporated) Adobe Notification Client -> C:\Program Files\WindowsApps\AdobeNotificationClient_3.0.1.1_x86__enpm4xejd91yc [2022-04-20] (Adobe Systems Incorporated) Connected Devices -> C:\Program Files\WindowsApps\34507Simplisidy.ShareAcrossDevices_4.2.6.0_x64__wtkr3v20s86d8 [2021-11-03] (Simplisidy) DragonCenter -> C:\Program Files\WindowsApps\9426MICRO-STARINTERNATION.DragonCenter_2.0.121.0_x64__kzh8wxbdkxb8p [2021-12-11] (MICRO-STAR INTERNATIONAL CO., LTD) [Startup Task] iTunes -> C:\Program Files\WindowsApps\AppleInc.iTunes_12124.1.57017.0_x64__nzyj5cx40ttqa [2022-05-18] (Apple Inc.) [Startup Task] Microsoft Advertising SDK for XAML -> C:\Program Files\WindowsApps\Microsoft.Advertising.Xaml_10.1811.1.0_x64__8wekyb3d8bbwe [2021-03-23] (Microsoft Corporation) [MS Ad] Microsoft Advertising SDK for XAML -> C:\Program Files\WindowsApps\Microsoft.Advertising.Xaml_10.1811.1.0_x86__8wekyb3d8bbwe [2021-03-23] (Microsoft Corporation) [MS Ad] Microsoft Solitaire Collection -> C:\Program Files\WindowsApps\Microsoft.MicrosoftSolitaireCollection_4.12.5120.0_x64__8wekyb3d8bbwe [2022-05-18] (Microsoft Studios) [MS Ad] Minecraft for Windows 10 -> C:\Program Files\WindowsApps\Microsoft.MinecraftUWP_1.18.3104.0_x64__8wekyb3d8bbwe [2022-04-28] (Microsoft Studios) Minecraft Launcher -> C:\Program Files\WindowsApps\Microsoft.4297127D64EC6_1.1.15.0_x64__8wekyb3d8bbwe [2022-05-09] (Microsoft Studios) NVIDIA Control Panel -> C:\Program Files\WindowsApps\NVIDIACorp.NVIDIAControlPanel_8.1.962.0_x64__56jybvy8sckqj [2022-05-02] (NVIDIA Corp.) Photos Media Engine Add-on -> C:\Program Files\WindowsApps\Microsoft.Photos.MediaEngineDLC_1.0.0.0_x64__8wekyb3d8bbwe [2020-10-02] (Microsoft Corporation) PowerPom - Pomodoro Timer -> C:\Program Files\WindowsApps\25994ProdDev.PowerPom-PomodoroTimer_1.1.6.0_x64__w3j63e9zf5dsr [2021-05-06] (Productive Team) Realtek Audio Control -> C:\Program Files\WindowsApps\RealtekSemiconductorCorp.RealtekAudioControl_1.35.271.0_x64__dt26b99r8h8gj [2022-05-16] (Realtek Semiconductor Corp) Spotify Music -> C:\Program Files\WindowsApps\SpotifyAB.SpotifyMusic_1.185.895.0_x86__zpdnekdrzrea0 [2022-05-13] (Spotify AB) [Startup Task] ========================= Devices: ================================ Name: NVIDIA High Definition Audio Description: NVIDIA High Definition Audio Class Guid: {4d36e96c-e325-11ce-bfc1-08002be10318} Manufacturer: NVIDIA Service: NVHDA Device ID: HDAUDIO\FUNC_01&VEN_10DE&DEV_0093&SUBSYS_14623755&REV_1001\5&DD97688&0&0001 Problem: : This device is disabled. (Code 22) Resolution: In Device Manager, click "Action", and then click "Enable Device". This starts the Enable Device wizard. Follow the instructions. ========================= Memory info: =================================== Percentage of memory in use: 29% Total physical RAM: 16333.05 MB Available physical RAM: 11480.56 MB Total Virtual: 25037.05 MB Available Virtual: 17910.09 MB ========================= Partitions: ===================================== 1 Drive c: (Samsung SSD) (Fixed) (Total:465.13 GB) (Free:99.5 GB) NTFS 2 Drive d: (Seagate SSHD) (Fixed) (Total:931.39 GB) (Free:170.24 GB) NTFS 3 Drive v: (WD Blue HDD) (Fixed) (Total:1863 GB) (Free:1066.58 GB) NTFS ========================= Users: ======================================== User accounts for \\TONYCOMPUTERONI Administrator Carlos DefaultAccount Guest WDAGUtilityAccount **** End of log **** |
