Hi there,
So I've got an MSI x470 motherboard and 6 standard working RGB LED fans. The fan hub recently busted and I'm looking for a suitable replacement. The real issue I've been having is that many fan hubs are either 5v 3pin and I'll be unable to plug it into my motherboard without an adapter or if they are 12v 4pin (which my motherboard supports) I cannot regulate fan speed?
Any recommendations on a suitable rgb LED fan hub and controller?
Thanks for reading / if you're able to help,
J
J
