Charger plugged in but not charging issue?
Din Djarin
22
3
33
Note: I think this is the right section for this topic.
I bought this laptop brand new not too long ago. One issue I'm having that is random is that when I plug the charger in, sometimes the light will flash and it won't charge. I have to mess around with it a little bit before it actually does charge. I'm really curious what could be causing this.
Check the power port on the laptop..if it is loose that may be your problem.
Take it back to where you bought it. If the charging port is the problem, that bit of hardware should be covered under the warranty. You don't want to start doing too much to a new laptop or the place that you bought it from will claim that you broke something.
Reactions: gus and jmarket
Do you have an update for us?
Hey, I apologize for not getting back sooner.
Taking it back has been out of the option for a while now. This thing already has everything on it.
The issue is very random, and I'm beginning to think is either program based, or has to do with the power saving options. Let me explain.
Most of the time the battery will plug in and charge just fine. Sometimes, it will flash and just not charge. Those times, I have to try various things ranging from the following. All of these have worked in different instances:
Closing all programs
Open browser windows so the computer is doing something.
Open a game.
Plug in or unplug my USB controller.
What I've also noticed, this issue mainly happens when my battery falls to very low levels. If the battery falls to, say, 50%, it plugs in and works fine.
Turn off the power save options and see if that has any change on the situation. Try different ones see if any make and differences.
Here are some other things to check. Where the power plugs into the laptop does it feel loose or wiggle?
Could be a bad power brick?
Could be a bad battery?
Could be a faulty system?
Yes it could be an misconfiguration some place?
I'll mess around with power saver stuff here in a bit.
The power cord doesn't wiggle when plugged into the laptop. It's secure.
If the battery or any of that was bad, wouldn't it struggle above 50%? Right now my laptop power is down to 58%. Plug in the charger, charging just fine. It's some type of issue that only happens if the battery falls to critical levels.
