Hi!
I newly built my first PC, and everything is running as it should, except for the case fans.
The problem i that every time i reboot the computer the case fans gets stuck on high speeds and wont slow down no matter hon long i leave it to idle. However, if i put the computer in to standby mode and the start it agian, the fans work as they should.
System specs:
Gigabyte z370 hd3 (rev 1.0)
i3 8100
8gb corsair vengeance ddr4 2666mhz
The case fans i use are 3 pin fans from phanteks (included in p400s). They're hooked up to the mobo and controlled by smart fan 5 in m.i.t
I have set them to voltage control, and they both have system 1 as temperature input.
Does anyone have any idea of why they are acting in this way?
System specs:
i3 8100
