Solved Case fan direction?
Brandon Byrnes
611
59
40
Wisconsin
I was wondering what direction I should have my case fans blowing. I have a back fan located towards the back top, a top fan and a front fan, not working yet since I have to get a three to one splitter. So currently only the back and top fans work but what direction should they be blowing. The top is right above the CPU and the back top is right behind The CPU, so I'm assuming have the back blow air in over the cpu and have the top exhaust that heated cpu air out the top? Am I correct?
Generally front case fans draw air in to the case, rear and top case fans blow air out of the case. If the side case fans are high up on the case then they too normally blow air out of the case
