The psu is 230volt and 500wHello
Give us a run down on what you upgraded.. Also your complete spec's on your psu.
It is a ATX 12v 500w and the make is builderWe need the name and model of that psu...
The brand is BUILDER and the part model is 500w builderOk still need a model number. Also isn't there a company brand on that ATX psu..
Thanks hopefully if I get a 8th or 9th generation it will workThanks for confirming it but bad news I`m afraid, the CPU and MB may be the same socket number but the MB is only compatible with 8th and 9th generation CPUs so the 6th generation I5 6500 is not compatible
You can confirm for yourself the compatibility issue if you check the CPU support list at ASUS here if you check the Customer questions & answers at amazon here you will see that someone asks about compatibility third question in.
Thanks look for one nowAs long as the CPU socket has not been damaged by fitting the I5 6500 an 8th generation would work but please note that a BIOS update may be required before an 9th generation will work and you can`t do a BIOS upgrade without a working CPU so you best go for an 8th gen CPU tbh.
