Solved Cam not working
ErikHaitch
4
58
Hi guys
Having a problem with my cam, im on win 10 at the moment
but it came with 8
but had the same probs before I updated to 10
I have delted the drivers and reinstalled, but still not working any heads up please
Asus flip laptop Im using
Now and agian it may work, but not often, if it does, it starts to fade out
and go off, but most times it will not work at all
OK ...just making sure the drivers that you installed were for Win 10 correct?
