Solved Buying an old laptop, Help
ChrisW
21
57
Hi Folks, hope all is well with you out there in these weird times.
This is my first post so I hope I have put it in the right section, if not apoligise before hand,
Its quite simple !
The problem. I was a fan of such games as Civalization 3, sim city 2000 etc I do not want to play them on my PC I own now nor do I want to buy a tower or desktop system soley for them.
I would like advice on buying an old laptop which would run these games but have not got a clue what spec or type to buy 2nd hand. It needs to run these smoothly and specked accordingley.
Any advice or pointers would be greatly appreciated bearing in mind I'm far from a techy ! I have all the cd's for installation,
Chris
Look for this in a laptop for Civilization 3
  • Processor: Intel Pentium III / AMD Athlon MP.
  • Graphics: AMD Radeon Xpress 1200 Series or NVIDIA GeForce 6200 LE.
  • System Memory: 128 MB RAM.
  • Storage: 1.5 GB Hard drive space.
  • DirectX 8 Compatible Graphics Card.
and for sim city 3
  • Processor: Intel Pentium III / AMD Athlon XP 1500+
  • Graphics: AMD Radeon X1270 or NVIDIA GeForce 6200
  • System Memory: 32 MB RAM
  • Storage: 50 MB Hard drive space
  • DirectX 9 Compatible Graphics Card
I would think that the laptop that has the spec's for sim city should run both..
Its quite simple !
Chris
Great, thankyou for your response at least I have something to go on now.
