Solved Bullgaurd premium and Superantispyware pro ???
Using two security suites together is never recommended irrespective of what the manufacturers of those security suites publish. Using two suites together can really bog down your pc, and even make it crash. Problem becomes large when more than one program tries to take control of some sort of malware. The fight never ends nicely.
Your best bet is to run one security suite as real time protection and then if you want have another ONLY working as an on demand scanner (that is NOT REAL TIME ) for a second opinion.
many thanks- I have Bullgaurd Premium which is just about to expire and Malwarebytes- will Malware bytes do the job of protecting my PC? thanks in advance
No security suite will give you 100% protection as they all will miss something sooner or later, but Malwarebytes is a reasonable choice. Nothing beats safe browsing. The suites with most favourable reviews would probably be Bitdefender or Kaspersky. But opinions are like backsides, everyone has one.
Is there anything more you need to know about your original question?
