Solved Building this pc. Is there any problems with it?
Hughbertus Maximus
4
24
I am building a new pc and these are the parts I've chosen (many due to price). Will this be fine or are there any suggestions you guys could make.
CaseCORSAIR OBSIDIAN SERIES™ 500D SE CASE
Processor (CPU)AMD Ryzen 9 5900X 12 Core CPU (3.7GHz-4.8GHz/70MB CACHE/AM4)
MotherboardASUS® CROSSHAIR VIII HERO WIFI (DDR4, PCIe 4.0, CrossFireX/SLI) - RGB Ready!
Memory (RAM)16GB Corsair VENGEANCE DDR4 3600MHz (2 x 8GB)
Graphics Card8GB NVIDIA GEFORCE RTX 3060 Ti - HDMI, DP, LHR
1st Storage DriveNOT REQUIRED
1st M.2 SSD Drive1TB SAMSUNG 980 PRO M.2, PCIe NVMe (up to 7000MB/R, 5000MB/W)
DVD/BLU-RAY DriveNOT REQUIRED
Power SupplyCORSAIR 750W RMx SERIES™ MODULAR 80 PLUS® GOLD, ULTRA QUIET
Power Cable1 x 1 Metre UK Power Cable (Kettle Lead)
Processor CoolingPCS FrostFlow 200 Series High Performance CPU Cooler
Thermal PasteARCTIC MX-4 EXTREME THERMAL CONDUCTIVITY COMPOUND
Extra Case Fans3x Corsair LL120 RGB LED Fan + Controller Kit
Sound CardASUS STRIX Raid Pro 7.1 PCIe sound card
Network Card10/100/1000 GIGABIT LAN PORT
The BIOS needs to be updated before the MB will be able to recognise the CPU.
The RAM is too fast for the CPU, see specs here
Never only have the one storage device, have a minimum of two, one just for Windows and one larger capacity drive for data only + using as one of your back up options.
Zero need for this as the MB already has outstanding audio capabilities and options.
Once the above build was up and running it would be a nice rig, nice but expensive.
Why do you feel the need to spend so much on a new build, what will it be used for, if only gaming there is no need to spend so much on a CPU, eight of the twelve cores would be doing zero most if not all of the time.
hi phillpower2,
Many thanks for the suggestions and sorry for the slow response,
I will change that ram for 3200MHz RAM.
I was originally going for an 8 core CPU but the 12 core option was available at a similar price from company I am buying it from. Reason I am choosing it is that I run a lot of modelling software.
I have to get that sound card to run 600 Ohm studio headphones which MB cannot support . The company should update the BIOS for me as well.
Again many thanks as I did not spot that ram issue!
Hello Hughbertus Maximus,
Glad we could help and thanks for filling in the gaps (y)
