Hi everyone!
>>> https://pcpartpicker.com/user/53muratdemircan/saved/#view=CvLDjX <<<
This build is for mostly 3d modeling and rendering.
I'll use 3dsMax+Corona Renderer, Lumion, and hopefully Unreal Engine.
I got some recommendations about changing AMD with Intel-I9-12900KF. This one has better single-thread performance but not sure if this makes it better than 5950x.
And motherboard, someone recommended me Asus Strix B550-XE Gaming Wifi (I first chose an X570 from MSI), and then someone else recommended Asus Strix B550-F Gaming Wifi.
I thought I can use Samsung SSD for windows and other software
Seagate for the project files I'll be working on
HDDs are mostly for storing 3d models/materials/finished projects...
Lumion is a real hardware monster.
In the link below; the High-end requirements section says 64GB and more. So, I want that 128GB of ram and AMD says on their official page, 5950x supports 3200 MHZ.
https://lumion.com/requirements.html
I'm also in between these 3 beauties.
The Fractal Torrent, the HZXT 510 Flow, and the Be Quiet Silent Base 802. I'm close to the first two, actually, especially to their appearances
In short, I'm a bit confused
Thanks!
Thanks!
