So my pc was working completely fine. I shut it down via windows and came back an hour later and turned it one. I got the MSI boot screen, and then the screen went black (but i still had a video signal) and sat like that for about 4 minutes, i checked my mobo debug lights and nothing was lit up so it wasn't anything with the motherboard or memory or CPU, I got impatient and hit the reset button on my front panel.
The computer booted back up and I immediately got a bsod with the above message "system32 ntoskrnl.exe is missing or corrupt". I ran chkdsk from a thumbdrive and it didn't detect any errors, I specifically used c:/chkdsk/f/r/x to check and repair any errors, but again it said there was no errors. So I exited chkdsk and tried booting back into windows normally and I got the same bsod.
I tried booting into safe mode and it went into safe mode and the screen flickered about 20 times and then my computer shutdown. My Windows version is the 1909 update which I installed after unstalling the 2004 updated becuase I was having problems. I just installed the 1909 version a couple weeks ago and it's been working fine. Am i correct in assuming that I once again am going to have to reinstall Windows? And if so can I just do the install that doesn't delete all my files and apps? To be honest I'm not really worried about my personal files since I have them all on a different drive, but installing all my apps again is gonna take hours.
And here's an idea, could I use a linux live cd, grab that system32 file off a Windows 10 iso, and using the linux live cd just replace the file on my os HDD with the file from the Windows 10 CD?
