Solved Bluetooth connections shaky
billriv
7
71
My AsRock B450M Pro4 AM4 motherboard does not have wifi or bluetooth onboard. I don't need the wifi, but I do need the bluetooth to connect some peripherals. I bought a generic 5.0 bluetooth dongle, but I have been having problems connecting my Skull Candy and Airpods headphones using Wndows 10 Home Edition. After the initial pairing and connection, if I for example, turn off the headphones after a music listening session, I cannot reconnect the headphones unless I remove the headphones from the list of paired devices and pair them again. If my headphones fall out of range as I walk away from my PC, I cannot reconnect unless I remove the headphones from the list of paired devices and must pair them again. After I turn off the headphones, Windows 10 bluetooth settings will confirm the headphones are paired and will allow a connection, but there will be no sound coming from those headphones, even though the Windows 10 sound settings window confirms the headphones are connected. Any time the headphones are disconnected, I cannot reconnect then unless I remove them from the list of bluetooth devices and pair them again.
Any suggestions on how to solve this issue?
Bill
What is the model and model number of that generic 5.0 bluetooth device?
