Bluescreens and many other problems
TudorBacu
4
27
Hello guys. I have a problem for over a few months. The proble is: I can't run league of legends, I can't run discord, I can't run certain apps and games, browsers like Opera and Chrome crashes, I can't use Nvidia Geforce Experience, and after 10-15 minutes, maybe 1-2 hours, depends, I get blue screens with the following messages: "Driver_ISQL_NOT_EQUAL_OR...", "CRITICAL SYSTEM CORRUPTION","INVALID K_MODE", I tried to reinstall the windows, I reinstalled, same problem, now I reinstalled into WIndows 8.1, same problem. I used programs like memtest86(all good), Intel CPU Diagnosis(all ***), HDD Diagnose(all ***). What can be the problem because is so annoying..
Hi there @TudorBacu and Welcome to PCHF :)
Please download the Sysnative BSOD Dump + System File Collection App - save to Documents folder.
Run the app - Double-click on the downloaded EXE file
Output = new folder created in Documents + a zipped version -- SysnativeFileCollectionApp folder + SysnativeFileCollectionApp.zip.
Please note that the app averages ~3 minutes to run on most systems; other systems - it my take as long as 10-15 minutes to run. Please be patient.
Also note: The app auto-zips the SysnativeFileCollectionApp output folder. It is located in your Documents folder.
Windows Explorer should open and highlight the zipped folder
Please attach the SysnativeFileCollectionApp.zip to your post and await further instructions :)
List Installed Programs
List Devices (Only Problems)
This explains your blue screens.
KMSPico interferes with the operating of Windows, and can introduce Malware into the machine. Unfortunately we are not able to provide support unless the system itself is legitimately activated with a valid product key. :(
Hey no worries :) We're here to help, but we can't assist when the OS itself is pirated/unknown of genuine status. We are always here to help you :) If possible, I would advise buying a key for W10 online, which is much much cheaper, for as little as $10 USD and re-installing the OS to get rid of KMSPico. After that, I honestly believe you won't have further issues :)
