When I first got my computer I would get the occasional bluescreen. Then one day it started bluescreening a lot, then every time it would try to boot back up, it would bluescreen again.
I tried to Reset this PC recovery option after trying some of the others and they didn't fix it. I selected a local install. As it would try to reinstall Windows, it would fail many times. I kept trying and eventually got Windows back up and running.
I thought the problem was fixed but 2 days ago it once again bluescreened and would bluescreen every time it tried to boot up. I tried Startup Repair, booting into Safe Mode, using a Restore Point, and none of them fixed the problem. This time if I tried to Reset this pc, it would fail right away saying there was a problem and it couldn't reinstall Windows and all I could do was click cancel.
I contacted hp support and they had me reset the bios then had me run tests on the hard drive, ram, and cpu which all passed. He said it wasn't a hardware problem and I needed to reinstall Windows from a usb drive. They said that if there are corrupt Windows files, that when you do a "reset this pc" and install from local, that those same corrupt files will still be there. They said if I used the Windows media creation tool and installed from a usb it should fix it.
I made the Windows usb drive with the media creation tool and used it to reinstall Windows. As it was installing, I kept getting bluescreens, which I found very strange why it would be getting bluescreens at this point if its not a hardware problem. After trying over and over, eventually Windows got installed.
When Windows got installed, I ran SFC and it said it found corrupt files and fixed them, which I found very strange why it would have corrupt files on a clean install I had just completed.
RIght now the computer is up and running but I am very nervous about whether it is really fixed or not at this point.
What would you do? I would love to do some thorough tests to try to see if everything is really ok or not. The last time I reinstalled Windows I thought it was ok but it didn't take long before I was back in a loop of bluescreen crashes.
