Solved Blue screen + hard drive not detected
Dank
34
Hey guys,
I built this computer 5 years ago and from the start I randomly blue screen, seemingly for no reason. Sometimes I will be gaming, sometimes I will have just rebooted and anywhere in between. Recently I started using my computer again and I'm having the same issue, only now when I reboot sometimes my hard drive isn't detected. I replaced my SATA cable and it still happens. Sometimes if I restart it will be detected, other times I have to unplug and re-plug the SATA cable.
I also am unable to upgrade to windows 10 but I think that's likely unrelated.
Windows 7 Home Premium
Service Pack 1
Intel(R) Core(TM) i5-3570K CPU @ 3.40GHz​
Memory (RAM)​
16.0 GB​
NVIDIA GeForce GTX 660​
64-bit operating system​
This is the error information I have collected after logging back in.
ERROR ONE
Problem signature:
Problem Event Name: BlueScreen
OS Version: 6.1.7601.2.1.0.768.3
Locale ID: 1033
Additional information about the problem:
BCCode: 50
BCP1: FFFFFA8061B32D88
BCP2: 0000000000000000
BCP3: FFFFF800032D3BFE
BCP4: 0000000000000005
OS Version: 6_1_7601
Service Pack: 1_0
Product: 768_1
Files that help describe the problem:
C:\Windows\Minidump\080220-20560-01.dmp
C:\Users\AppData\Local\Temp\WER-85363-0.sysdata.xml
Read our privacy statement online:
http://go.microsoft.com/fwlink/?linkid=104288&clcid=0x0409
If the online privacy statement is not available, please read our privacy statement offline:
C:\Windows\system32\en-US\erofflps.txt
ERROR TWO
Problem signature:
Locale ID: 1033
BCCode: 109
BCP1: A3A039D8A477663C
BCP2: B3B7465EF6F43852
BCP3: FFFFF8000325E8E0
BCP4: 0000000000000001
Service Pack: 1_0
Product: 768_1
C:\Windows\Minidump\080220-17768-01.dmp
C:\Users\AppData\Local\Temp\WER-68624-0.sysdata.xml
PLEASE HELP ME!
Hello Dank,
I suspect that you have more than one issue going on here with both hardware and software being involved.
Hello Dank,
Thank you for your reply,
After a lot of hard work on both my part as well as a Microsoft Support Agent, we were able to get me upgraded to windows 10. I did keep my old files so if it is still relevant I can still get that information for you.
Does me now being on windows 10 change things?
If you have any further issues please provide all the information that was requested in my reply #2 and we will go from there.
You are welcome btw :)
