For unknown reasons the power light on my Asus mini-laptop has started blinking (green and orange). It's definitely the power light because it goes off whenever I remove the power cable connector (which I do only when the laptop is turned off). The laptop itself nonetheless continues to function properly, otherwise I wouldn't be able to post this query. Likewise the latop's battery is still fully charged. . . leastways according to Control Panel. So what could be the likely cause? Should I be concerned?
The laptop runs on Windows 10 Home Edition.
Many thanks
Many thanks
