Bigger Fonts In Gnote
See if these links help at all.
  • Font size
    There are actually four options in this part of the menu: Small, Normal, Large, and Huge. Each option represents a font size to use for the selected text. To modify the font size, select text and then select Small, Normal, Large, or Huge.
