The best workgroup printers in this list are ideal for busy offices with lots of network-connected PCs. These printers will allow any computer connected to the network to print, and are best used for offices with 10 or more employees.
The best workgroup printers need to be fast and powerful, then, to cope with demand. That means they should have plenty of on-board memory to store jobs, while having RAM and processors that allow them to keep up with the workload.
They also need to be capable of printing out high numbers of documents a month. So, not only do they need to be fast, but they should also be economical with ink without compromising on image quality.
Because of the high number of printouts the best workgroup printers have to handle, they should also have high-capacity paper trays – so you don't have to keep filling it up with more paper throughout the workday.
Of course, all the best workgroup printers will have network connections, either wired via Ethernet or Wi-Fi (or preferably both for maximum flexibility).
So, read on for our pick of the best workgroup printers, and let our built-in price comparison tool help find you the best deals as well.
With a print speed of 55 pages per minute and room for a whole ream of paper on board, this compact device can keep a large work group printing continuously. While the initial outlay for this monochrome device is high, its running costs are impressively low, so you should find you save money in the long run. Although it only prints in black and white, the print quality is superb.
Who says a workgroup printer has to be big and bulky? The Brother HL-L5100DN is a compact printer, but don't be put off – this little workgroup printer can handle plenty of jobs, with a high print speed and large paper capacity. It does lack some features, however, such as Wi-Fi, so you'll need to make sure you can plug it in to your wired network. But for small offices where space is a premium, this is one of the best workgroup printers you can buy – and it's pretty cheap to run as well!
It might seem expensive for a desktop device, but this colour laser printer comes with impressive specifications and a slick smartphone-style interface. It already has a huge capacity for paper thanks to the 550-sheet tray, but you can double that by adding a second tray. Xerox includes a generous amount of toner too, enough for 2,000 colour or 3,000 mono pages. The five-inch touchscreen makes setup and operation simple and while Wi-Fi is not fitted as standard, it’s a simple £50 upgrade. Most importantly, the print quality is excellent with the Pantone-approved colours really making your documents stand out.
Kyocera’s printer comes with a capacity for 500 sheets of paper and large toner cartridges, which makes it suitable for a big workgroup or a busy home office. It prints quickly in duplex mode and runs very quietly too. If you're expecting your office to go through a lot of printouts every month, then the fact that the Kyocera Ecosys P6230cdn is built to handle large volumes without you having to restock either paper or toner makes this one of the best workgroup printers money can buy.
The HP LaserJet Pro MFP M227fdw is a brilliant multifunction device that's one of the best workgroup printers for small and medium-sized businesses. It boasts excellent print quality and very fast print speeds, plus the 300 sheet paper capacity should mean even the busiest of offices shouldn't have to keep refilling the printer too often. It only prints in mono, however, and it's not the fastest laser printer in the world, but it offers a good selection of features for the price.
Canon’s multifunction laser printer has great build quality, a stylish design (as far as printers are go, anyway), and offers plenty of features for printing securely in a large workgroup. You can also scan, copy and fax wirelessly from this device as well. The large touchscreen control panel makes it easy to set up and use, and while it is quite noisey, the print speeds are nice and fast. Though the initial cost is high, it comes with enough toner for up to 6,300 mono, or 5,000 colour pages. This means you shouldn't have to refill for a while.
This unassuming square box provides an affordable means of churning out monochrome pages in a busy small office atmosphere. It can hold 250 sheets of paper and a toner cartridge capable of delivering up to 6,000 printed pages, which makes it one of the best workgroup printers around, especially for smaller offices where you don't want to spend a fortune on a printer. The included starter cartridge can manage only 700 pages, but by including all of the key features, such a Wi-Fi, duplex printing and robust security at a competitive price, we can strongly recommend it.
Ricoh’s colour printer comes with the essential features, such as Wi-Fi connectivity, duplex mode and secure printing built in, which makes it an ideal workgroup printer. Speed isn't the fastest, nor is the 250 sheet capacity the largest, but print quality if fantastic – and don't forget this printer will print in both mono and color.
If you need an all-in-one device to serve a small workgroup in a small office, this inexpensive laser printer makes a lot of sense. If it looks a little top-heavy, that’s because the impressively small footprint isn’t much larger than a sheet of A4. But that doesn’t stop it from swallowing 250 sheets of paper and offering an automatic document feeder that can hold 50 more. Lexmark includes enough black toner for a somewhat stingy 700 monochrome prints, but high capacity replacements are available that can print 6,000 pages. With duplex printing, Wi-Fi and security features included, it can do nearly everything a much more expensive MFD can.
- Read the full review: Xerox VersaLink B600DN
- Read the full review: Brother HL-L5100DN
- Read the full review: Xerox VersaLink C400DN
- Read the full review: Kyocera Ecosys P6230cdn
- Read the full review: HP LaserJet Pro MFP M227fdw
- Read the full review: Canon i-Sensys MF735Cx
- Read the full review: Ricoh SP C261DNw
- Read the full review: Lexmark MB2236adw
- Check out our list of the best printers, no matter if they are ink jet or laser
