I need to move my outboard Disk drives to about 6-7' from the computer, which is beyond the length of the devices' 2 1/2' cables which came with them. I know there are two ways of doing this and would appreciate recommendations of which is the better way. The devices are mostly USB 2, with a couple of USB 3, but the computer ports are only USB 2.
#1) Replace the standard USB cables with 10' cables
#2) Get Active Repeater extension cables and connect them to the standard USB cables (e.g.https://www.amazon.com/AmazonBasics...coding=UTF8&psc=1&refRID=AX65BNDSEQJBTGK7ZW45 for USB 2.0 and https://www.amazon.com/Cable-Matter...439106&sr=1-4&keywords=usb+3.0+extender+cable for 3.0 cables)
The advantage to #2 is that I would have only three cables across the 6' of floor from the device shelf - there are only three free USB ports on the computer - and I would just connect and disconnect the individual devices' standard USB cables on the shelf from the extenders as needed. The disadvantage may be loss of signal quality and/or data speed because of the cable-to-cable connection.
The advantage to #1 is that there isn't any possibility of signal quality and/or data speed loss because of the cable-to-cable connection. The disadvantage may be that the quality of these 10' cables are inferior to the standard cables that came with the disk drives and on their own introduce signal quality and/or data speed loss.
I expect that in either option I would need cables with gold-plated connectors.
Any recommendation (or alternatives) will be most appreciated.
Thank you.
Thank you.
