Best PC for photo editing 2021: top desktops for Photoshop
Welcome to our pick of the best PC for photo editing, where on this page we'll look at top computers that will help you make sure your photographs look their every best.
No matter if you're a professional photographer or a keen hobbyist, if you're looking for the best PC for photo editing for your needs, then you're going to need to keep an eye out for certain things.
Whenever you're working with high resolution photos, you'll ideally have a PC that can easily handle this high res files. While a dedicated graphics card is ideal, for many people that may be overkill, so just make sure the PC has a powerful integrated GPU. You won't need a high-end graphics card – unless you’re also doing video editing or 3D rendering. However, it's worth buying a PC with a decent mid-range or higher graphics card to keep up with your workload.
The best PC for photo editing should also have enough RAM so you can have several programs and images open at once, as well as a high capacity hard drive in which to store your photos. Buying a photo editing PC that already comes with plenty of storage space will save you having to fiddle about installing extra hard drives later on. We recommend at least 16GB of RAM and 1TB or higher of storage (SSD, not hard drives).
We've included some great all-in-one PCs in this list. These powerful and stylish photo editing PCs are space-saving and easy to set up, as all the components are housed behind the screens. The ones in this list have been chosen in part because their screens are bright, vibrant and accurately show off colors for photo editing. If you go for a standard desktop PC, however, make sure you pair it with one of our picks of the best photo editing monitors.
For something a bit more portable, also make sure you check out our pick of the best laptops for photographers and photo editing.
  • In search of a photo book to store your edited prints?
Best PC for photo editing at a glance:​
  1. iMac (27-inch, 2020)
  2. Apple Mac mini 2018
  3. Lenovo ThinkCentre M900
  4. Microsoft Surface Studio 2
  5. Apple iMac Pro
  6. Lenovo Yoga A940
  7. iMac (27-inch, 2019)
  8. HP Pavilion Wave
  9. Intel Hades Canyon NUC
iMac 27-inch (2020)
(Image credit: Apple)
1. iMac (27-inch, 2020)​
A formidable AIO for photo editing
CPU: 10th-generation Intel Core i5 – i9 | Graphics: AMD Radeon Pro 5300 - Radeon Pro 5700 XT | RAM: 8GB – 128GB 2666MHz DDR4 | Storage: 256GB – 8TB SSD | Display: 27-inch (diagonal) 5120 x 2880 Retina 5K display
Improved internals
Can be configured to be very powerful
Design is getting old
Just two Thunderbolt ports
Even though the iMac 27-inch’s last update was only recent, Apple couldn’t help but step up in the upgrades department with its follow-up. Specs-wise, this model sports some massive improvements while also upgrading its webcam and microphones for a felicitous update. More people are working from home these days, and this seems like the best all-in-one PC to invest in without being forced to make some considerable space in your existing area. Sure, its overall design hasn’t seen so much as a tweak, making it look a bit tired, but power trumps design for photo editing.
Read the full review: iMac (27-inch, 2020)
2. Apple Mac mini 2018​
A brilliant mini PC for photo editing
CPU: Intel Core i3 - i7 | Graphics: Intel UHD Graphics 630 | RAM: Up to 64GB | Storage: Up to 2TB SSD | Connectivity: Gigabit Ethernet, 802.11ac Wi-Fi | Dimensions (W x D x H): 19.7 x 19.7 x 3.6cm
Same small design
Four USB-C Thunderbolt 3 ports
Integrated graphics aren’t all that
The new Mac mini was a long time coming, but it was well worth the wait, as Apple has packed it with some brilliant modern components, including the latest 6-core processors from Intel, along with support for up to 64GB RAM and loads of storage as well, all in that small and stylish body we've come to love. It's perfectly powerful enough for photo editing, and small enough for photographers to carry around with them. The only disappointment is that it does not come with discrete graphics, but Intel's integrated UHD Graphics 630 aren't too shabby, and you can also plug in an external GPU for extra graphical oomph.
3. Lenovo ThinkCentre M900​
High end components for a good price
CPU: Intel Core i7 | Graphics: Up to NVIDIA Quadro K420 2 GB DVI + DP | RAM: Up to 64GB | Storage: 1TB HDD | Connectivity: Gigabit Ethernet, 802.11ac Wi-Fi | Dimensions (W x D x H): 175 x 413 x 406mm
Powerful CPU
Dedicated GPU
Not the biggest amount of ports
The Lenovo ThinkCentre M900 is an excellent desktop PC for photo editing, as it combines speed and power with an excellent build quality and reliability which is essential for PCs used for heavy duty image manipulation. Best of all, the Lenovo ThinkCentre M900 comes in a range of configurations, with the top-end model boasting a huge amount of power. This flexibility lets you build a Lenovo ThinkCentre M900 that suits your needs, and there's plenty of room to upgrade and expand this desktop in the future.
Surface Studio 2
The Surface Studio 2 ups the power significantly, making it a much more future-proof device. (Image credit: TechRadar)
4. Microsoft Surface Studio 2​
An artist’s dream come true
CPU: Intel Core i7 | Graphics: Nvidia GeForce GTX 1060 - GTX 1070 | RAM: 16GB – 32GB | Storage: 1TB - 2TB SSD | Display: 28-inch 4,500 x 3,000 PixelSense display
Powerful
Nothing like it
Very expensive
If you’re looking for an incredibly powerful, yet stylishly designed, all-in-one computer that’s not made by Apple, then Microsoft’s brilliant Surface Studio 2 will be for you. It comes at a price, but for build quality and performance, you’ll not want to look any further, especially if you work with photo editing applications. Microsoft's all-in-one PC fits comfortably on a desk, and it's built-in screen makes your photos look fantastic, even before you've edited them. As it run Windows 10 you get a huge range of comparible photo editing apps as well.
5. Apple iMac Pro​
A stylish addition to any office
CPU: Intel Xeon W | Graphics: AMD Vega 56, Vega 64 | RAM: 32GB, 64GB | Storage: 1TB ssD | Connectivity: Ethernet, 802.11ac Wi-Fi | Dimensions (W x D x H): 65 x 20.3 x 51.6cm
Most powerful Mac ever
Excellent design
Very expensive
Non user-upgradable
If you're a professional photographer and digital creative, then the iMac Pro is one of the best PCs money can buy. This is a seriously powerful all-in-one that was released last year with cutting edge tech, and a choice of powerful Intel Xeon W processors, bags of RAM and hefty graphical processing power. All of this in an iconic Apple design. If you have the budget for it, the iMac Pro is one of the best PCs for photo editing money can buy. However, for some people, you may find it has a level of power that you do not require, so read on for more modest (and affordable) PCs for photo editing.
Lenovo Yoga A940
Lenovo Yoga A940 is plenty powerful to meet the needs of creative professionals. (Image credit: Future)
6. Lenovo Yoga A940​
An iMac alternative
CPU: 8th-generation Intel Core i7-8700 | Graphics: AMD Radeon RX 560 4 GB | RAM: 32 GB DDR4 2666 MHz | Storage: 1 TB 5400 RPM + 256 GB PCIe SSD | Display: 27" 4K UHD (3840 x 2160) IPS Multi-touch
Good price
Stylus included
Older components
Screen not great in direct light
Lenovo’s latest all-in-one offering isn’t as powerful as Apple’s premium AIO, the iMac Pro, or even the recently updated iMac, which now offers a 9th-generation Intel Core configuration. After all, the 8th-generation chips and Radeon RX 560 graphics are aging at this point. However, it is still plenty powerful to meet the needs of professional photographers who can't afford Apple's more pricey machines. It's one of the best PCs for photo editing thanks to its screen that offers 100% Adobe RGB support and Dolby Vision, plus a stylus and dial as well, for better control over your photo editing work.
7. iMac (27-inch, 2019)​
Now with 8th-generation processors
CPU: 8th-generation Intel Core i5 – 9th-generation Intel Core i5 | Graphics: AMD Radeon Pro 570X – 580X, Intel UHD Graphics 630 | RAM: 8GB - 64GB | Screen: 27-inch Retina 5K 5,120 x 2,880 P3 | Storage: 1TB – 2TB Fusion Drive | Dimensions (H x W x D): 20.3 x 25.6 x 8 inches (51.6 x 65.0 x 20.3cm)
Stunning 5K display
Quiet under load
SSD upgrades are expensive
If the iMac Pro above is too expensive (and offers a level of performance that you simply don't need) but you want an Apple all-in-one, then the standard iMac is more than capable of helping you with your photo editing. While the iMac 2019 doesn’t feature a touchscreen or an adjustable stand, the option for a 4K P3 wide color gamut display means it will accurately display your photos. Plus, there’s the fact that because the iMac (27-inch, 2019) is no longer the latest model, so it should be getting some tempting price cuts.
HP Pavilion Mini
8. HP Pavilion Wave​
A great Windows alternative to the Mac Pro
CPU: Intel Core i3 – Intel Core i5 | Graphics: Intel HD Graphics 530 – AMD Radeon R9 M470 | RAM: 8GB | Storage: 1TB HDD
Unique, stylish cylindrical form factor
Clever and effective audio solution
No optical audio port
Unflattering specs
Though at first you might confuse it for a fabric-woven Mac Pro refresh, the HP Pavilion Wave is anything but. This compact Windows machine packs in 6th-generation Intel Core processors and optional discrete AMD graphics with a uniquely integrated Bang & Olufsen speaker. Wrapped in a handsome fabric exterior, this is the perfect PC to have on the desk. If you love listening to music while you edit your photos, then this is a brilliant – and stylish – PC to consider.
9. Intel Hades Canyon NUC​
Don’t let its size fool you
CPU: Intel Core i7-8809G | Graphics: Radeon RX Vega M GH graphics (4GB HBM2 VRAM), Intel UHD Graphics 630 | RAM: N/A | Storage: N/A
Lots of ports
Easy to upgrade
Expensive
If you’re looking for a great desktop experience for photo editing, but don’t have a lot of space, look no further than the Intel Hades Canyon NUC. In this tiny bare-bones PC, you have an insanely powerful 8th-generation Intel Core i7 processor, and discrete-class Radeon graphics – once you throw in some RAM and storage, you've got a small and easily portable PC that can handle photo editing with ease. If you often travel around and want a powerful and dependable PC for photo editing, then this is definitely worth considering.
Below is an excerpt of “The Digital Darkroom: The Definitive Guide to Photo Editing” by James Abbott, published by Ilex Press (£17.70 on Amazon.co.uk). James talks briefly about the differences between Apple and Windows-based devices when it comes to photo editing.
"With two major systems available in Apple and Windows computers, which one is truly better for photo editing? All professional photographers use Macs, don’t they? And aren’t Macs simply much better at running photo editing software than Windows PCs? When Photoshop 1.0 was launched back in 1990 it was Mac-only software, and it wasn’t until 1993 with version 2.5 that it became available for Windows computers. Macs remained the favorite option for graphic designers, and this, alongside the fact that digital typography began on Macs, helped to create the idea that Macs were best for running Photoshop.
The reality is that running Adobe and Affinity Photo (ed: probably the most potent rival to Adobe's hegemony) - is identical on both Mac and Windows PCs. There really are no differences in performance, features or functionality, although faster and more powerful computers of both types are preferred. This means that you don’t have to switch from Windows to Apple when you first begin editing – you can use whichever system you prefer.
I used to use Macs, but once Apple made it difficult to upgrade components such as RAM and hard drives, I switched to a Windows PC because I knew I’d be able to upgrade all components when I wanted to. The switchover was seamless, and while I miss the clean simplicity of the macOS operating system, the versatility of the Windows PCs I’ve owned since I switched has been well worth it.
Just one more thing: with improvements in the processing power of both Android and iOS tablets, it’s now possible to edit images using these smart devices. The ability to use touch can provide a highly tactile approach to editing, and with Affinity Photo and different versions of Photoshop and Lightroom available for tablets, there’s huge scope for using these devices.
From a workflow point of view, computers remain the best devices for image editing because of their greater processing power, larger screens and increased space for storing image files. Tablets, however, are a great option when travelling for image editing on the go.
