Mining is still alive and well in 2019, and if you’re ready to jump on the bandwagon, one of the best mining motherboards should be at the top of your list. Fortunately, we know this as well as anyone and have crafted a guide to the best mining motherboards on the market today, so you can get to mining, rather than spending hours researching.
The best mining motherboard, in theory, will work hand in hand with a mining graphics card so that everything attached to your mining rig works together in perfect harmony. We’re not exaggerating when we say that the best motherboards are the nervous system of your mining rig, and getting a good one will help you maximise the profit from your mining rig.
There’s a lot to take in when you’re looking for a mining motherboard, but we here at TechRAdar have your back. Right here you’ll find all the best mining motherboards on the market, so whether you’re mining for Ethereum, Bitcoin or some other cryptocurrency, you won’t be left out in the cold.
Supporting a jaw-dropping 19 GPUs – more than any other board on this list, the Asus B250 Mining Expert is easily the best mining motherboard you can buy today. Plus, thanks to a special mining mode, you won’t have to screw around with the BIOS in order to maximize your bitcoin payout. On top of these quality of life improvements, the B250 Mining Expert boasts the same quality standards we’ve come to expect from Asus, the only real drawback is its scarcity – it can sometimes be extremely hard to find, likely due to how great it really is.
Thanks to its extremely solid build quality and slots for up to 13 GPUs, the AsRock H110 BTC+ is one of the best mining motherboards you can buy today. These features allow you to expand as needed, so you won’t find a much better future-proof board. It might be a bit overkill, as Windows 10 only supports eight GPUs, but there’s no harm in preparing for future updates. The AsRock H110 BTC+ may not be the best motherboard for mining if you’re a beginner, but if you’re looking for a more advanced platform – you can’t go wrong with the AsRock H110 Pro BTC+.
If you’re not looking for a motherboard that can run 13 GPUs at once, the Gigabyte GA-H110-D3A might just be the best mining motherboard for you. It can still handle up to six GPUs, and it has the excellent build quality Gigabyte is known for – which means it can withstand the intensive conditions cryptocurrency mining can create. It also includes electrostatic, power failure and high temperature protection, which is essential for a machine running 24/7. Unlike some other mining motherboards, it can be used for non-mining applications, giving it a flexibility that we really appreciate.
The Biostar TB250-BTC Pro is a great value mining motherboard that brings some excellent and advanced mining features, such as support for up to 12 GPUs, for a very competitive price. Even if you're not going to be using the full 12 PCI slots for graphics cards, this could be a wise investment if you plan on scaling up your mining operation in the future. The only real downside of this motherboard is that it's quite difficult to get hold of, so keep an eye on our price tracker on this page, as it will tell you when it's in stock, and what the best price is!
The MSI Z170A Gaming Pro Carbon is one of the best mining motherboards not just because it’s good at mining, but because it’s also good for gaming. Thanks to a number of gaming-centric features you’d typically associate with boards found in the best gaming PCs you can have a machine that does both. You’ll get four DDR4 memory slots, plenty of ports and connectivity that appeals to hardcore gamers. And, it’s no slouch when it comes to mining either – with support for up to seven graphics cards. For the best versatile mining motherboard, you can’t do much better.
Asus’ ROG brand is well known for making gaming components and peripherals, but these peripherals are also great for mining cryptocurrency. The Asus ROG Strix Z270E supports seven graphics cards, which is a decent number for a mining rig. It also has a ton of other features, though many of them are focused on gaming. That’s great if you’re looking for something that can pull double duty, but if you’re not interested in gaming, you’ll find the additional features pointless at best and distracting at worst.
- What is Bitcoin? Understanding Bitcoin and cryptocurrencies
- How to buy Bitcoins in 2018
- Bitcoin vs distributed ledger vs Ethereum vs blockchain
- The best Bitcoin exchanges 2018
- While you’re at it, we’ve also found the best gaming desktop PC you can buy
- Check out also the best VPN services of 2018.
