Best Headset
max jani
25
My previous headphones not working well. So I want to change it. Someone suggest me some headphones Sony WH-1000XM3, Bose Quiet Comfort 35 II, Sony WH-1000XM4. Can anyone suggest me which one should i buy?
I've always gone by budget and online reviews.
I usually stay away from the dirt cheap stuff and the overly priced stuff.
aim for something on the slightly higher side of the mid-range offerings.
most manufactures have forum sites, not only for support, but for complaints - they can be a great source of first hand experience.
then there are the product review sites, but they tend to be fan boys, or were given the component to play with (and keep) and usually just pay lip service to keep in the good books.
