Solved Best 3800-4133 ram for AMD Ryzen 7 3800x and MPG X570
hopelessgamer
27
Hey all,
I'm building a relatively budget gaming PC and need some help with choosing the best ram but don't know much regarding the compatibility of timing/latency with those parts.
I have a Ryzen 7 3800x processor and a MSI MPG X570 Gaming Plus motherboard. I would like to run 3800-4133 ram but cant figure out which ram would be the best latency/timing wise for that motherboard/processor combo.
Any recommendations?
Thanks!
This link should help..
The CPU is only compatible with RAM up to 3200MHz so for anything faster the CPU and RAM both need to be overclocked, you will not get budget RAM with the specs that you are quoting either I`m afraid, an example here
