Battery replacement for Nuu Mobile X5
Usually you can just match the model number of the battery and go from there,when ordering a replacement.
I could only find a replacement X5 battery in India I`m afraid :(
The X4 battery even if it would fit is too weak at 2250 mAh whereas the X5 battery is 2950 mAh.
