I have been using the same equipment for awhile now, but when I moved the audio now generates static and also ever 5 sec or so pops.
I have been browsing around the forums trying various suggestions. I decided to make a post of my own to see if maybe I am missing something.
My build
I have a Mixer (Behringer XENYX X1222 USB), the USB connects to my computer. (I have tired moving it to different ports on the pc from front to back) Connected to the mixer is a headset and mic(mic is AKG P220)(headset is sennheiser)
I know its the PC, because when I shutdown the PC the popping stops, also when I start up something that uses audio the popping stops(example; teamspeak, youtube, anything that generates audio)
I also was using a program called OBS (Open Broadcasting Software) and the people that I was broadcasting to heard static, all the time.
I have my computer plugged into a APC, so when the power goes out I have time to shutdown my PC. I was using this and did not have a problem before.
If you need to know anything else about the build of my computer please let me know
Thank You
Raz
My build
Thank You
Raz
