Solved Air mouse dongle?
caskin
PCHF Donator
May 31, 2017
186
22
84
Would someone be good enough to explain what the purpose of the dongle which came with my Weechip air mouse.?Plus if they could help me set it up I would appreciate it thanks
Hello Caskin..
That would be the receiving antenna for the remote mouse. Did the Weechip come with an instructional CD ?
Reactions: caskin
Hello Caskin..
Really appreciate your reply, although the instructions are hopeless (No CD just a sheet of poor grammer) I did eventually gather it had to be placed as you say,as soon as that is done air mouse is up and running with no set up required.Plus a quick IR set up for shutting down and all is well with the world....so once again many thanks. Can be marked up as solved!
Reactions: veeg
