Advanced scaling options problem
grangler
4
53
Hi all been having this problem for a few days now after installed new nvidia driver then changed back to older version to test.
I have my desk top set as 2880 x 1620 as this is my sweet spot for 60fps gaming.
I have added set custom scaling to 150 percent so the text is crisp and clear every time i restart my pc it reverts back to 200 then i have to change it back again and rearange my icons.
I have also edited it with regedit to decimal 154 and it still bloody changes back it is doing my nut in if any one could help it would be apriciated thanks mark.
Running windows 10 pro Ryzen 1600x nvidia gtx 1070 16gb ram.
also not my area.
I've dabbled with scaling in Win10 a few times and always reverted back to 100% as some programs just don't display scaled text correctly.
from memory CCleaner and MBAM were the 2 culprits and it was on a Surface tablet.
also not my area.
I had it with origin used changed dpi with the compatability setting in the desktop shortcut thanks anyway.
Dont know if this helpes my active resolution is lower than my destop resolution sca;ing saves if i have the desktop at 4k but icons are blury when scaled and a couple of programs just wont scale correctly fine when not scaled but then i cant read the wrighting coming up 50 get the magnifying glass.
Thanks for help everyone.
